Old 05-06-2018, 12:10 PM   #1
LancePower
Drives: 2020 BRZ tS
Sound Tube Question
Does the OEM Sound Tube lock or snap into the firewall?
Or does just sorta lay in there?
Thanks.
LancePower is offline   Reply With Quote
Old 05-06-2018, 12:19 PM   #2
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
its a tube that connects to a connector that is in the hole in your firewall. i had mine plugged after the deleted but it fell out so i stopped caring.
Breadman is offline   Reply With Quote
Old 05-06-2018, 01:33 PM   #3
norcalpb
norcalpb's Avatar
It’s a loose rubber like lock for sure.
I put the sti sound changer in there and it seemed like it would fall out but it’s still in there.
Old 05-06-2018, 01:45 PM   #4
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I ran 2awg power wire through the hole.
I LIKE TIRES!
Old 05-06-2018, 01:49 PM   #5
Ultramaroon
not playing cards
Ultramaroon's Avatar
I left it installed to keep the correct part mated against the seal. Then I plugged the hose just upstream at the elbow in the engine bay.
Old 05-06-2018, 05:23 PM   #6
sly
sly's Avatar
Drives: 2016 Cosworth 2.2 BRZ
You can plug the opening in the firewall with the plastic plug that goes in the glovebox cigarette lighter. It fits perfectly. I removed my tube and used the plastic plug to close the hole for the sound tube.
sly is offline   Reply With Quote
Old 05-06-2018, 06:10 PM   #7
Ultramaroon
not playing cards
I tapered a wooden dowel and shoved it into the upstream fitting.
Old 05-06-2018, 06:40 PM   #8
LancePower
Drives: 2020 BRZ tS
Thanks, all.
I just had just installed TRD Intake and that last piece of the Sound Tube fell out during the process. I couldn't make it "snap" back into that rubber hole. So I was just making sure I wasn't missing something. But it sounds like it just sort of lays in there.
Old 05-06-2018, 06:52 PM   #9
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Drives: 2018 BRZ Ts - CWP
Yes, it just lays in there, inside the rubber grommet that is in the hole in the firewall. It does not snap in. It just slides through, so don't worry about it too much.
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS
DD/4WD - Colorado ZR2 Bison - Mallett Supercharger
brzaapi is offline   Reply With Quote
Old 05-06-2018, 07:36 PM   #10
Old 05-06-2018, 07:49 PM   #11
Ultramaroon
not playing cards
It was more of a press fit.
Sound tube CPO 76 Cosmetic Modification (Interior/Exterior/Lighting) 1 01-05-2018 06:14 PM
wtb: sound tube delete inlet tube Jimmy817 Engine, Exhaust, Bolt-Ons 1 12-21-2014 09:15 AM
FS: TRD Sound Tube its_the_biz Engine, Exhaust, Bolt-Ons 0 12-14-2014 04:46 PM
FS OEM sound tube Vlady Engine, Exhaust, Bolt-Ons 0 10-16-2013 07:59 PM
Sound tube mod? smbrm Engine, Exhaust, Transmission 25 06-20-2012 07:24 PM
