Old 05-02-2018, 04:29 AM   #1
ZionsWrath
Thanks
ZionsWrath's Avatar
Calipers no good after storage
I put in an AP racing sprint kit about 4 years ago and have the oem calipers on my shelf. I was cleaning the garage and decided to take a peek. The dust boots are junk. Falling apart to the touch.
Is there any special way to store calipers?
Guess I better check my rear calipers since they are stock and prpbably send in my AP kit for a rebuild.
Just posting to show others and get any feedback. My brakes works fine right now.
Old 05-02-2018, 06:00 AM   #2
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Something doesn't seem right here. The rubber shouldn't be deteriorating after such a short period of time. Were they stored near a window (heat or direct sunlight) or are there chemicals stored nearby (subjected to the vapors or direct contact)? Heat, UV light, ozone and variety of chemicals will cause break down in the rubber.
BirdTRD is offline   Reply With Quote
Old 05-02-2018, 07:57 AM   #3
ZionsWrath
Thanks
ZionsWrath's Avatar
No, just in an unheated garage but it never gets below freezing. In a box with paper towels. I guess i could have cleaned them off with brake clean and depressed the piston but they were barely a couple years old at the time i didnt think it would matter i guess.
The slide pin boots are good but both calipers look like this. I'll chalk it up to track use. Also the pistons wont retract. Heat cycles seem a brutal thing.
Old 05-02-2018, 12:44 PM   #4
ls1ac
ls1ac's Avatar
Hard to see in the pic, are the boots ripped?
If not clean them up and retract the pistons using a brake tool of a large channel lock. The seals around the pistons get stuck to the walls after sitting.
If the boots are ripped cut them off and check the piston for damage and rebuild as needed.
Old 05-02-2018, 01:06 PM   #5
wparsons
wparsons's Avatar
How much track use did those calipers see? The boots might've been cracking from heat before going into storage.
flickr
dual calipers vs big brake calipers Docmattic Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 05-30-2017 04:51 PM
Good deal on brembo calipers or not? red1993sol Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 10-07-2013 02:26 AM
Wheel Storage GotM Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 05-26-2013 05:12 PM
Took it out of storage for a day dexterium CANADA 17 01-21-2013 08:41 PM
storage? subaruferrucci Scion FR-S / Toyota 86 GT86 General Forum 3 06-11-2012 03:50 PM
