Old 04-25-2018, 12:00 PM   #1
Mdulin
Drives: Scion Frs
Will 255s fit my 18x10 Rota Titan
My wheels are Rota titans 18x10 with a 37mm offset
I ordered Michelin PS4s 255/18/zr40
Last owner had 235s on and they were stretched AF.
Mdulin is offline   Reply With Quote
Old 04-25-2018, 12:05 PM   #2
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Stock suspension?
They'll fit, I had 255s on my 9.5" wide wheel.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 04-25-2018, 12:05 PM   #3
AutoNewb
Drives: 2014 Subaru BRZ Sterling Silver
You should've figured out if they fit before you ordered them.
According to Tirerack...
The rim width range is 8.5-10", so you should be good.
https://www.tirerack.com/tires/tires...Pilot+Sport+4S
AutoNewb is offline   Reply With Quote
Old 04-25-2018, 12:09 PM   #4
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
If you ordered 255/40-18 tires, they're going to be considerably taller than stock, which will change your gearing, speedo, and appearance. The correct size would be 255/35-18.
EDIT: I'd recommend trying to cancel the order and reorder with the correct profile. And if you have to, eat the restock fees because I don't think you'll be happy with any part of using the taller tire.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
venturaII is offline   Reply With Quote
Rota Titan 17x9 +42 Leftyluff Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 06-21-2015 12:45 AM
Where to buy rota titan? Zixxerguy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 05-21-2015 08:56 PM
Rota Titan 18x8.5 Bongertz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 11-07-2014 03:54 AM
FS: Rota Titan (17x8 +42) Fizz Australia Classifieds 2 12-12-2013 09:12 PM
Introducing the new ROTA TITAN Scooby South Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 01-18-2013 02:31 PM
