Old 04-23-2018, 12:58 AM   #1
86TOYO2k17
Drives: 2017 toyota 86
Trans mount Cusco collar vs Whiteline insert
Don’t ask me why, but I already have both.
I am unsure which one to install / is better?
I figure they both work pretty well, which one has least NVH?
Or pros and cons to both?
This is a DD that I can’t stop throwing away money on... basically want a fun streetable DD, for rare track days.
I already have sti motor mounts, whiteline diff support insert, whiteline subframe bushing inserts.
Old 04-23-2018, 01:27 AM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
I might be wrong, but IIRC whiteline limited gearbox movement just vertically, cusco's also longitudinally. Don't have these, have Perrin's, which works more like Cusco's i guess. I hear now slight supercharger-like gear whine at lowest gears (probably at others too, but drown in road/tire noise at higher speeds). It's quiet/not loud, so i ignore that.
Old 04-23-2018, 11:41 PM   #3
NRXRaptor
Whiteline will add hardly any nvh. The perrin will add some aforementioned gear whine. You'll also hear the tranny turning over when you're in neutral. Easily liveable. I made the hole in the whiteline insert larger to accommodate the perrin, so I'm using both, which is cool I guess
NRXRaptor is offline   Reply With Quote
Old 04-24-2018, 01:15 AM   #4
86TOYO2k17
I wonder if I could toss the lower big washer part of Cusco and use both. Trying to clean up a little drivetrain slop with least amount of NVH.
cusco collar, mount insert, transmission mount
DIY - Whiteline Rear Crossmember Mount Insert Bushings F1point4 DIY (Do-It-Yourself) Guides 91 01-17-2021 02:23 AM
FS: Whiteline Subframe Insert Mount Bushings (KDT926) bombardius Brakes, Suspension, Chassis 2 04-16-2016 10:49 AM
fs: Perrin trans mount and whiteline trans bushing RWD_FR-S Transmission and Driveline 1 01-02-2014 05:34 PM
FS: Kartboy Short Shifter w/Rear Bushing & Trans mount insert Opie Transmission and Driveline 4 09-16-2013 05:43 PM
Whiteline diff bushings and trans mount insert. Simmons Transmission and Driveline 7 06-09-2013 08:45 PM
