Old 04-20-2018, 01:39 PM   #1
efactor84
efactor84's Avatar
Drives: 2015 Scion FR-S
Angry 1320 header v2 problem
I'm wondering if anyone is having this issue with v2 headers from 1320 performance. I installed it for the first time with berk HFC. I took the front pipe off and reinstall the stock front pipe same result. It makes the whistle sound like v1. Has anybody tried resolving this? I'm wondering if it could be the o2 spacer the cause. I never had this issue with OFH before it was sold a long time ago when I was living stateside.
efactor84 is offline   Reply With Quote
Old 04-20-2018, 03:04 PM   #2
Teseo
Drives: frs
Check the flex pipe, maybe have a crack on it
Old 04-20-2018, 03:15 PM   #3
efactor84
efactor84's Avatar
Figures kind of disappointed and under the impression it was resolved. Probably take it to a wielder shop in Germany and let them do the work to replace them. When I had someone rev it for me, it sounded from the tensioner which will make no sense since it has like 20k on it. My fuel trims would be - 2.34 which tells me it is or not the headers; running OFT Stage 2+ tune. My previous experience was the OFH and it was like + 9 and that was a loose o2 sensor and easy fix.
Old 04-30-2018, 02:44 AM   #4
ryankay
Drives: 2014 Subaru BRZ
Are you using the O2 spacer with a tune?
The spacer is junk(I had multiple lean codes from it leaking) and it makes a horrible whistle sound.
Jut put the o2 sensor back in the stream if it’s tuned, the tune tells your ECU to ignore codes from it except for the lean code for leaks.
Otherwise I like my 1320 header/overpipe combo. It was a good deal, although it would be better without flexpipe
ryankay is offline   Reply With Quote
1320 Performance UEL Header? Ronin Sascha Engine, Exhaust, Transmission 53 06-27-2018 07:39 AM
1320 Header & Overpipe X Factor Engine, Exhaust, Transmission 31 02-07-2016 01:43 AM
1320 uel header, opinions? Mr_YUzU_FRS Engine, Exhaust, Transmission 2 09-30-2015 07:00 PM
