Old 04-18-2018, 12:55 AM   #1
ARTBRZ
Aloha!
ARTBRZ's Avatar
Clutch cylinder question
I was bleeding my clutch and I accidentally ran it dry. Do I need to do a bench bleed? I’m found conflicting information (no consensus) in the forum.
ARTBRZ is offline   Reply With Quote
Old 05-24-2018, 08:55 AM   #2
jcw99
Drives: swp mt '14 brz premium
Just saw your post - no bleeding is required - as you hopefully already have found out.
jcw99 is offline   Reply With Quote
Old 05-24-2018, 02:38 PM   #3
Ultramaroon
not playing cards
Ultramaroon's Avatar
I should update my DIY. I made a big deal about bench bleeding purely in an effort to avoid controversy.
Totally agree with you.
Clutch Master cylinder - bleeder screw size? Joesurf79 Engine, Exhaust, Transmission 3 12-28-2019 08:16 AM
Any clutch master cylinder options that are more compact? Clash0901 Engine, Exhaust, Transmission 3 07-22-2018 06:32 PM
FS: OEM Clutch Slave Master Cylinder MicheleAbbate Transmission and Driveline 3 05-09-2016 04:48 PM
Clutch Slave Cylinder KAR Southern California 4 08-08-2015 09:25 PM
OEM Clutch Slave Cylinder $20 shipped SlowCone Transmission and Driveline 0 04-25-2015 05:07 PM
