Old 04-10-2018, 02:57 PM   #1
E85Brz
Drives: 2013 - E85 WRB Subaru BRZ
2013 Brz Build Thread: Andromeda
8/17/16 - 99,8xx Miles - Crashed my 2008 Vw Rabbit 2.5l 5cyl
8/26/16 - 53,751 Miles - Bought a 2013 Subaru Brz from Brunswick Dealership in Brunswick Ohio, Paid $20,160 Out the door tax and title
8/27/16 - 53,7xx Miles - Installed Agency Power UEL Headers $650
8/30/16 - 53,8xx Miles - Installed Eibach Lowering Springs $250
9/17/16 - 54,xxx Miles - Installed OFT Stg2 E85 Tune
10/25/16 - 54,xxx Miles - Installed OZ Msw Type 25 Rims $850
10/25/16 - 54,xxx Miles - Installed Perrin Intake Tube - $120
10/29/16 - 55,xxx Miles - Installed Works Axleback - $250 Used
3/1/17 - 58,xxx Miles - Dyno'd Car at Redline tuning - $75
Car Made 198.5whp 142.6wtq On Mustang Dyno with E85
6/1/17 - 60,xxx Miles - Installed Bayson R Front lip - $50 Used
6/16/17 - 61,xxx Miles - Ran first Quarter Mile ever
14.64 at 98Mph on a 90+ Degree Day
8/6/17 - 64,xxx Miles - Installed Valenti Blk/Gold Tail lights - $350
10/6/17 - 67,xxx Miles - Blacked out Headlights - $10
[B]11/1/17 - Bought AeroCatch Hood latches $100
11/21/17 - 70,xxx Miles - Installed SBD 400x V3 Turbo Kit $1600
11/21/17 - 70,xxx Miles - Bought OFT Turbo Tune $250
[B]1/16/18 - Bought Mishimoto Catch Can $100
3/x/18 - 73,xxx Miles - Installed SPC Lower Control arms - $100 Used
3/x/18 - 73,xxx Miles - Installed StreetKings frontpipe $80
[B]3/12/18 - Bought Seibon Carbon Ts Hood $100
3/30/18 - 73,xxx Miles - Blow a Hole in the block
4/8/18 - Sold Turbo Kit $2000
4/8/18 - Sold StreetKings Frontpipe $50
4/9/18 - Sold OFT $400
4/9/18 - Sold OEM Headunit $150
4/10/18 - Ordered CX Racing LS1 Swap Kit $1076
4/10/18 - Bought Lm7 block $300
4/14/18 - Bought Z06 T56 Tranny $1000
4/20/18 - Pulled Brz Motor
4/20/18 - Sold Stock Brz Transmission $300
4/23/18 - Bought 695/1500 Brz Shifter trim piece off TRD Car $112
4/24/18 - Ordered Ls1 t56 Bellhousing $275
4/24/18 - Ordered Z06 Clutch and Flywheel Kit $390
5/1/18 - Regasketed the entire motor
5/2/18 - Received bellhousing and Clutch kit
5/2/18 - Realized im a complete retard and put Z06 trans up for sale
5/6/18 - Bought Ls6 Intake manifold for $250
5/6/18 - Bought Ls1 DBW Throttle body $100
5/6/18 - Test fit exhaust
5/9/18 - Bought GTO Oil pan $330
5/9/18 - Installed GTO Front Sump Oil pan
5/11/18 - Installed Ls6 Intake Manifold and Ls1 Throttlebody
5/14/18 - Wilwood Master Cylinder Bought $100
5/14/18 - Test fit motor in the car to see what i needed to clearance
(Oil pan hit sway bar and the back of the head hit the clutch master)
6/13/18 - Bought a very special t56 $4000
6/24/18 - Bolted z06 clutch setup onto the motor
6/24/18 - Bolted on the T56
6/27/18 - Bought Ls6 Fuel Rail $100
6/27/18 - Bought GTO Gas Pedal $100
6/29/18 - Ls Ignition Wires $50
6/29/18 - Ls Ignition Coils $30
7/01/18 - Connector pigtail for pedal S1479
7/3/18 - Bolted on the T56
7/3/18 - Throwout Bleeder Extension Kit bought $50
7/4/18 - Attempting to cut trans tunnel
7/15/18 - Bought Quickcar Switch Panel $120
7/17/18 - Car sponsored By Burnt Rubber Garage
7/21/18 - Looking towards rear mount turbo Setups
8/18/18 - $450 Brian Tooley Stage 4 Cam Kit
8/19/18 - $330 Ordered Vorslag Mishimoto Ls Swap Radiotor
8/22/18 - $125 Ls swap Fuse block harness setup
8/22/18 - Designing wrap designs for the car
8/28/18 - $300 Bought Second 5.3 for salvaging parts
9/22/18 - $100 New OEM Headgaskets
9/25/18 - $600 Heads ported, shaved, valves done
9/25/18 - $300 Block Decked, cleaned, painted
9/25/18 - Waiting for Block to come back from Machinist
9/25/18 - $117 Gto T56 shifter, last one didnt work
[B]3/12/18 - Bought Aero Catch Hood Latches $100
5/6/18 - Test Fit exhaust for the first time
5/9/18 - Received Oil pan
5/9/18 - Installed Oil pan
5/9/18 - Installed Ls6 Intake Manifold and Ls1 Throttlebody
6/27/18 - Bought Ls6 Fuel rails $100
E85Brz is offline   Reply With Quote
The Following 4 Users Say Thank You to E85Brz For This Useful Post:
Draco_PR23 (05-07-2018), jbsali (04-10-2018), Sportsguy83 (04-10-2018), wired (09-27-2018)
Old 04-10-2018, 03:56 PM   #2
jbsali
jbsali's Avatar
Drives: 2014 Subaru BRZ (Limited)
I really likes how you noted milage for all these mods. its something i wish i did for my own brz.
jbsali is offline   Reply With Quote
Old 04-10-2018, 05:49 PM   #3
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
There's a lot of documented bad decisions in that list.
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline   Reply With Quote
Old 04-28-2018, 01:06 AM   #4
E85Brz
Thanks haha, i try to keep it organized
Old 04-28-2018, 10:00 AM   #5
all4spl
that transmission absolutely will not work in this car
all4spl is offline   Reply With Quote
Old 04-28-2018, 11:13 AM   #6
wutsaiu
wutsaiu's Avatar
Drives: 2015 Raven V8
Indeed.
You can sometimes modify the corvette transmissions into the correct “format” but it’s easier and cheaper to buy the right one in the first place. The amount of time and money I spent on modifying the C7 7-speed probably wasn’t worth it but at least it’s unique, this one looks like the C5 Z06 t56 which isn’t that great.
wutsaiu is offline   Reply With Quote
Old 04-28-2018, 03:36 PM   #7
E85Brz
Originally Posted by wutsaiu View Post
Indeed.
See i guess i forgot to mention. It already has the shaft changed because it came out of a ls swapped supra. So i ordered a bellhousing for $250. Now i just need a tailend and bam its ready. Thats why i went with that tranny
The Following User Says Thank You to E85Brz For This Useful Post:
wutsaiu (04-28-2018)
Old 04-28-2018, 03:49 PM   #8
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Members Car Journals section?
Old 05-03-2018, 09:37 PM   #9
drew_kar
drew_kar's Avatar
Drives: WRB Brz / SR S14
How did you blow your FA20?
drew_kar is offline   Reply With Quote
Old 05-03-2018, 11:41 PM   #10
E85Brz
No clue. Heard a tink tink tink BANG. then i saw smoke. sounded like a bolt hitting sheet metal. no previous signs
Old 06-29-2018, 01:00 AM   #11
E85Brz
Motor goes in sunday
updated thread 6/29/18
Old 07-01-2018, 08:15 PM   #12
Irace86.2.0
Old 07-21-2018, 01:06 PM   #13
E85Brz
Except it has pics?
e85brz, ls1, subaru, swap, turbo
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 07:52 PM
Golfyankee2121's 2013 Argento FR-S Build Thread golfyankee2121 Member's Car Journals 13 11-08-2016 07:52 AM
Superpenguin's "Not Another Build Thread!" Build Thread superpenguin Member's Car Journals 7 06-17-2015 04:00 PM
Andromeda box Zoik Electronics | Audio | NAV | Infotainment 0 05-30-2015 11:55 AM
JDB3's 2013 Argento FR-S Build Thread (Updated) golfyankee2121 Member's Car Journals 3 04-14-2015 12:15 PM
