Old 04-09-2018, 04:46 AM   #1
rmr
rmr's Avatar
Drives: FRS 10-series
200TW summer tires + freezing weather okay to install?
Hi, I've searched but haven't found a definitive answer
I have a new set of Ventus RS4s on new wheels and have some time off over next few days and was hoping to install. The weather here has been unseasonably cold and forecast is calling for temperatures dipping below freezing at night, going up to 5C or 40F during the day
Just wondering if there is any harm in installing these with the freezing temps over night. I have heard the soft rubber shouldn't be exposed to these temperatures and could be damaged. Obviously grip will be down but I don't plan on driving very far, just hoping to get the install out of the way as long as it wont hurt the rubber out in the cold
Thanks for any help
rmr is offline   Reply With Quote
Old 04-09-2018, 07:07 AM   #2
cueball89
Drives: 15 Impreza
From tire rack
Note: Tires exposed to temperatures of 20 degrees F (-7 degrees C) or lower must be permitted to gradually return to temperatures of at least 40 degrees F (5 degrees C) for at least 24 hours before they are flexed in any manner, such as by adjusting inflation pressures, mounting them on wheels, or using them to support, roll or drive a vehicle.
Flexing of the specialized rubber compounds used in Extreme Performance Summer tires during cold-weather use can result in irreversible compound cracking. While compound cracking is not a warrantable condition because it occurs as the result of improper use or storage, tires exhibiting compound cracking must be replaced.
cueball89 is offline   Reply With Quote
Old 04-09-2018, 07:15 AM   #3
churchx
churchx's Avatar
Drives: 2014 GT86
I wouldn't care so much about state of tires, as to safety of myself and car. Crash damage repair may cost much more then what tire set costs. If there are temps below freezing during nights, there still one may stumble upon some formed during night from moisture in air black ice in first half of day on roads. Better garage car with summer tires to when lowest temps during night-day get above 5C.
Old 04-09-2018, 11:12 AM   #4
rmr
rmr's Avatar
Originally Posted by cueball89 View Post
From tire rack
This is what I thought, the cold isn't great for the compound, guess I'll be waiting to make the install
No doubt, thanks
SOLD!! Motegi Racing MR125's w/TPMS and worn RE11-A 200TW tires Keenercarguy Wheels and Tires 28 07-20-2017 01:49 AM
2016 Federal 595 RS-RR tires NOW IN STOCK! 200TW starting at $100!! FRSport.com Wheels and Tires 31 02-14-2017 01:45 PM
WTB: 245/40/17 200TW+ Tires! TruthfulDeception Want-To-Buy Requests 0 08-16-2016 12:07 PM
Maxxis VR-1, New 200TW "Extreme summer performance" tire CSG Mike Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 06-01-2016 05:04 PM
summer or all-season tires? freezing temps? rainmonkey Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 04-07-2013 01:11 PM
