Old 04-04-2018, 05:30 PM   #1
killy
Drives: BRZ Limited
EDFC PRO Strut kit and height adjustements
Hello,
can anyone that has already installed the EDFC Pro system here help me, I am trying to understand this:
In order to adjust the ride height on the tein coilovers the correct procedure is to loosen the bottom mount locking ring and then rotate the whole coilover assembly clockwise or counterclock wise, depending if you want to lower or rise the car. That's the way I alsways did. Then screw tight the ring once again.. the end.
Now that I have to install the EDFC pro I have to install the strut kit, based on the videos I have seen, these brakets prevents the strut type coilover to rotate and save the wirings.
But does that mean that I will not be able to adjust the ride heght with this mounted on the coilovers?
killy is offline   Reply With Quote
Old 04-04-2018, 07:51 PM   #2
You can. You need to either remove the motor, or disconnect the harness so the motor can spin freely.
Old 04-05-2018, 02:27 AM   #3
killy
Drives: BRZ Limited
Really? that's good news!
so basically what are those brackets doing if the strut can rotate with them? I probably didn't get how the work very well....
Old 06-20-2018, 12:58 PM   #4
ldam
Drives:
anyone know where i can connect the orange cable from the signal converter to my frs(don't know where the vehicle speed signal line is on 2015 frs)
ldam is offline   Reply With Quote
Old 06-20-2018, 04:00 PM   #5
wparsons
wparsons's Avatar
There won't be a speed signal line, it's derived from the wheel speed sensors and will be sent over CANBUS to the cluster.
flickr
Old 06-20-2018, 08:27 PM   #6
ldam
Drives:
Is there anything way I can connect EDFC active pro so it can pick up the vehicle speed?
Old 06-21-2018, 03:10 AM   #7
churchx
churchx's Avatar
Drives: 2014 GT86
Wasn't there possibility to add own gps receiver for that to EDFC?
Old 06-21-2018, 04:32 AM   #8
banane63
banane63's Avatar
Drives: BRZ Club blanc perle
EDK07-P8022 EDFC ACTIVE GPS KIT (Optional)$80.00
Envoyé de mon S60 en utilisant Tapatalk
Collecteur et frontpipe Supersprint full décat - Catback Remus
Admission directe Greddy - Kit Flexfuel et map Ecutek Visconti Tuning - Tein Street Advance EDFC Pro - NED modine - OZ Alleggerita 18 Michelin PS4 - Wilwood 6 pistons
banane63 is offline   Reply With Quote
Old 06-21-2018, 03:22 PM   #9
GPS receiver
Old 06-21-2018, 03:40 PM   #10
ldam
Drives:
Found the vss wire
FS: Tein Edfc Active Pro byun Brakes, Suspension, Chassis 9 01-14-2017 05:21 PM
FS: Tein EDFC Active Pro byun Brakes, Suspension, Chassis 6 11-18-2016 01:33 PM
Best place to get the EDFC stuff? Ludacrits Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 04-15-2015 07:28 AM
For those who ride, there's a group ride happening tomorrow if you're interested. Yamaha_R6 Northwest 3 03-07-2014 09:32 PM
