Old 04-04-2018, 11:30 AM   #1
Jollibee86
Jollibee86's Avatar
Drives: 2014 Scion FR-S
Aftermarket Headunit with Aftermarket Amp
So I recently bought a new aftermarket class D microamp to replace the factory amp for the door speakers. I connected the low-level outputs from the factory Headunit. Everything works well but now I want to install an aftermarket HU. I just wanted to ask if I need to connect the low level outputs going to the amp from the RCA outputs of the aftermarket instead of the included harness. I'm thinking the output from the Metra harness is high-level meant to go directly to speakers without an amp.
Jollibee86 is offline   Reply With Quote
Old 04-04-2018, 01:10 PM   #2
Jollibee86
Jollibee86's Avatar
Delete this thread, found out that my Pioneer GM-D1004 amp has an automatic signal-sensing feature. Doesn't matter if it's high or low-level inputs
Old 04-04-2018, 09:39 PM   #3
TOLM
Drives: Brz
You'd better use the low level inputs between the hu and amp for sound quality reasons
TOLM is offline   Reply With Quote
OEM Audio with Aftermarket Headunit iConformed Electronics | Audio | NAV | Infotainment 0 07-03-2015 01:52 AM
OEM+ audio with aftermarket headunit lfuentes92 Audio/Visual, Electronics, Infotainment, NAV 2 11-17-2013 08:56 PM
USB/AUX connection for aftermarket headunit. kf417 Electronics | Audio | NAV | Infotainment 1 10-24-2013 06:49 PM
OEM mic w/ aftermarket headunit Powered By Jay Electronics | Audio | NAV | Infotainment 0 07-21-2012 07:59 PM
aftermarket headunit and USB /AUX encity5 Electronics | Audio | NAV | Infotainment 0 07-16-2012 07:28 AM
