Old 04-02-2018, 02:40 PM   #1
stlgrym3
Drives: 2017 Subaru BRZ Limited
Questions for AT owners about Sport mode
1. Do u leave it at Sport mode all the time?
2. Can we change the mode back and forth from Sport to regular while car is moving?
stlgrym3 is offline   Reply With Quote
Old 04-02-2018, 02:46 PM   #2
Vital
Drives: 2015 BRZ
Yes, you can change it back and forth while driving it wont harm anything.
Vital is offline   Reply With Quote
Old 04-02-2018, 03:36 PM   #3
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
1. yes
2. yes
shiumai is offline   Reply With Quote
Old 04-02-2018, 05:03 PM   #4
Twinz
Twinz's Avatar
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
(I have a 15' AT)
1. No
2. Yes
The "sport" mode for the transmission itself is great if you want to do some performance driving. (It eats fuel for no good reason if you are not in any particular hurry though)
The "sport" mode for the stability/traction control system is useless on 13-16 models. The 17's call it "track" mode and it actually works well for performance driving, but I have never tested its ability to "bail you out" of a bad situation.
Twinz is offline   Reply With Quote
Old 04-02-2018, 05:17 PM   #5
stlgrym3
I have a ‘17 AT I’ve only used the Sport mode, never tried the Track mode yet. I assume it’s just Sport with traction turned off, am I correct?
Old 04-02-2018, 05:29 PM   #6
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
I always just use manual mode, it's more fun shifting my self.
Lunatic is offline   Reply With Quote
Old 04-02-2018, 06:55 PM   #7
Twinz
Twinz's Avatar
I have not experimented with the 17's. (Just did a few runs on an autocross course in one)
-But, on my 15', the sport button in the middle is just for the transmission. The nannies stay in full effect. The button to the right, (The 13-16 models also say "Sport" there but the 17's say "track") is supposed to dial back the nannies....no effect on the transmission as far as I know.
On the 17's, the right button ("track") works pretty well. The nannies generally stay out of your way unless you start getting out of hand. The 13-16 models are a different story. There, the right "sport" button is a joke. The nannies jump in to save you before you even start to push the car.
I don't know if the new track mode is better/faster programming that is just as likely to save you from a mistake as the old "sport" mode, or if it just comes with a higher risk of not being able to bail you out if you get in over your head.
Old 04-02-2018, 07:26 PM   #8
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
I use the paddles 100% of the time and never use sport. I also take off TCS 100% of the time and it's so much fun to drive especially with my car now making 295-300whp/255wtq.
SUB-FT86 is offline   Reply With Quote
Old 04-02-2018, 07:41 PM   #9
navanodd
Drives: 2013 BRZ Sport-tech WRB
I use manual mode 100% of the time, which performs shifts the same as if it were in sport mode. Been driving like that for over 4 years now.
navanodd is offline   Reply With Quote
Old 04-03-2018, 02:54 AM   #10
Razgriz
Drives: 2016 Scion FRS Release Series 2.0
I have a '16 and never use the regular sport mode. The VSC Sport affects both nannies and the transmission on my car. It will hold gear and upshift later than normal. I like that a bit more since the nannies are really aggressive.
I switch between VSC sport and manual/traction off a lot depending on my mode. But I been driving like an old man a lot more lately too and just full nannies/auto.
Razgriz is offline   Reply With Quote
Old 04-03-2018, 12:23 PM   #11
tyler_win_photo
tyler_win_photo's Avatar
Sport mode only takes effect if you drive it automatic/drive all the time as all it does is hold the shifts to a higher rpm. Once you use the paddles there is no difference. Contrary to belief it does not make the transmission shift harder.
tyler_win_photo is offline   Reply With Quote
The Following User Says Thank You to tyler_win_photo For This Useful Post:
Gunman (04-03-2018)
Old 04-03-2018, 10:34 PM   #12
Aluma007
Drives: 2017 Brz
also keeps revs higher in all gears...sport cruises at a good 1k +rpms more to keep the engine responsive.
Aluma007 is offline   Reply With Quote
Vsc sport and Sport mode at the same time? Markk Scion FR-S / Toyota 86 GT86 General Forum 22 09-28-2015 02:07 PM
AT Sport Mode - What does it do exactly? karbon BRZ First-Gen (2012+) — General Topics 49 09-02-2014 02:40 AM
DIY Auto VSC Sport and AT Sport Mode Seattle944t DIY (Do-It-Yourself) Guides 0 09-08-2013 05:02 PM
Cruise control with Sport or VSC Sport mode notout86 Scion FR-S / Toyota 86 GT86 General Forum 12 08-29-2013 06:50 PM
sport mode... pr086 Scion FR-S / Toyota 86 GT86 General Forum 6 06-01-2012 11:50 AM
