Old 04-02-2018, 11:58 AM   #1
Pinoy_FRS
Drives: Ultramarine
Clutch advice
Hey fellas,
So recently my TOB has been starting to fail on me so instead of just replacing that alone I might as well replace the whole clutch while I'm there (85k miles). My car is my DD and as of now I am not planning to go boost. I do like my spirited drives along with having a little fun in an open parking lot.
The clutch I was looking at was the Exedy OEM Kit #FJK1005 along with their lightweight flywheel #TF02. A different alternative I was looking at was the ACT clutch kit with the lightweight flywheel #SB8-HDSS. Both seemed fairly reasonable for me since I don't expect to be making that much power but at the same time have the car a tiny bit rev happy. I do like the feel of a little stiffer clutch with a tiny bit more bite.
So my question is which of these kits would you guys recommend? Both have a similar price range and from what I've read both companies have great credit when it comes to clutches. As of now I am just looking at these two but I am open to other suggestions as long as it's within my budget
~$500-$800
Thanks guys!
Pinoy_FRS is offline   Reply With Quote
Old 04-02-2018, 12:18 PM   #2
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Exedy is pretty good quality. I had the Southbend Clutch Stage 2 (which was basically a tweaked Exedy) and it was a great kit. I didn't do the fly wheel, though.
MS, CSCS, TSAC-F, CPT
Old 04-02-2018, 12:28 PM   #3
humfrz
Originally Posted by Pinoy_FRS View Post
Hey fellas,
~$500-$800
Thanks guys!
I'd suggest you just go with OEM.
humfrz
Old 04-02-2018, 01:08 PM   #4
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
OEM as well. Once you go with stronger clutches, you'll also need to upgrade the clutch fork as they are known to break due to the increased pressures. If you want it to feel stiffer, you can do the clutch slave cylinder swap posted here.
JimmyMac is offline   Reply With Quote
Old 04-02-2018, 01:16 PM   #5
Pinoy_FRS
Drives: Ultramarine
Thanks guys! Appreciate the advice!
Old 04-02-2018, 01:41 PM   #6
Pinoy_FRS
Drives: Ultramarine
Now is it really worth getting the lightweight flywheel?
Old 04-02-2018, 01:44 PM   #7
weederr33
weederr33's Avatar
Nope!
Old 04-02-2018, 01:49 PM   #8
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I had an ACT. It would hang up on me, and the lightened flywheel is not what you want for a DD. It would shutter all the time.
I went back to stock flywheel with a South Bend stage 2 daily and now much better.
Old 04-02-2018, 01:52 PM   #9
humfrz
For a DD, I'd stick with the stock flywheel ...... it's already light enough .....
humfrz
Old 04-02-2018, 01:53 PM   #10
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
For a daily, non boosted, go with OEM or Southbend that allows you to keep OEM FW. The lgihter FW will not be pleasant for a DD, specially when you're not making any crazy power.
Old 04-03-2018, 01:12 AM   #11
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
I installed the ACT SB7-HDSS (Full face street /w streetlight flywheel). Definitely daily-able, but not without consequences.
I enjoy driving, and I track the car. I don't mind the additional noise and inconveniences of a lightweight flywheel. The response is great, but does take practice and changing some of your city driving habits.
If you do go with an OE replacement type kit, I would recommend picking up and using the 2017 TOB from the dealer.
EndlessAzure is online now   Reply With Quote
Old 04-03-2018, 03:42 AM   #12
dhuang
Cannonball Record Guy
dhuang's Avatar
Drives: Series.Yellow, 4C, Fit
When my TOB was on the verge of dying, I too had the ACT SB7-HDSS w/ the Velox billet clutch fork professionally installed on my previous FR-S... It started failing ~6-7k miles in (locked me out of gears, etc).
I appreciated the responsiveness of the lighter FW, but ACT quality control had more to be desired in my particular case.
I would stick to OEM.
2017 Series.Yellow
2013 Whiteout
VINwiki - Changing Automotive History
dhuang is offline   Reply With Quote
Old 04-03-2018, 06:09 AM   #13
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
And while you're at it get the Velox fork and pivot.
Old 04-03-2018, 07:40 AM   #14
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Did you try adjusting your clutch pedal height to see if that fixed the problem?
To the OP:
If you have no plan to have more power then OEM. If you want a bump up in power support then do the Exedy Stage 1, but get the forged billet fork. Don’t ever get a LWFW for a DD.
Need to buy a clutch tomorrow, OEM or Stage 1, any advice on where to go? YouShallKnow Southern California 10 12-22-2014 01:31 AM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 Redline360 Transmission and Driveline 2 07-30-2012 10:01 AM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 12:06 PM
