Old 03-23-2018, 04:00 PM   #1
lortto
Drives: Subaru BRZ 16'
Oft not writing properly brz 2016
Hi, i have problems writing on ECU it says its okay and shows no errors when i write map, but i still get CEL with code p0037 even i have turned it off on romraider. Does anyone have similar problems?
lortto is offline   Reply With Quote
Old 03-23-2018, 04:14 PM   #2
steve99
the OFT is fine, the tune is fine
P0037 is
Potential causes of a P0037 trouble code may include:
  • Bank 1, sensor #2 oxygen sensor heater element has failed
  • Physical damage to heated oxygen sensor has occurred
  • Control circuit (or voltage feed, depending on system) is shorted to ground
  • PCM Oxygen sensor heater driver has failed
you need to check rear 02 sensor and wiring/plug
That's an actual fault.
you will need to do more than just disable code to remove rear 02 function, you will have to disable its compensations in tune as well as a bunch of cel codes.
Old 03-23-2018, 08:58 PM   #3
lortto
P0037 is
I cheked the plug and wiring, fuse box got a lot of dust but i didnt see any blown fuses either. Can i measure the sensor so i know its the sensor itself that is broken. I have catless headers and the o2 sensor has a spacer.
Old 03-23-2018, 09:08 PM   #4
lortto
Oh also i forgot to mension the launch control doesnt change even i change the value
Old 03-23-2018, 11:53 PM   #5
steve99
write stock rom/tune back to car
do you still get the cel code.
if its all good
you likely have mismatched tune/definition or mismatched tune for your car ie incorrect calibration id
Old 03-24-2018, 04:37 AM   #6
lortto
if its all good
When i bought the car it had some tune already done, so i dont have the stock map for it and OFM shows that my cal id is 10G, but OFT shows 01G when plugged to car.
Old 03-24-2018, 04:46 AM   #7
steve99
See the Tactrix link in colour below, at end of that post is most of the stock roms, jiust unzip them and you will be able to load either the F10G or A01G stock to your car, jist load it to one of the tune slots in oft
Old 03-24-2018, 07:33 PM   #8
lortto
I loaded the F10G stock map and still get the p0037, does it have anyother fuses that 29?
Old 03-24-2018, 09:04 PM   #9
steve99
Its the EFI HTR fuse
my guess would be o2 sensor was damaged during install due excessive torque applied
Problem with writing roms from OFT to car!! 86ARMN Software Tuning 9 05-16-2016 09:01 PM
Windshield Writing FRSure Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 04-03-2014 08:20 AM
