Old 03-22-2018, 04:43 PM   #1
zrimmi
Drives: 2013 Scion FRS
86/FRS bumper swap
Would it be possible to install a 2018 86 OEM bumper onto a 2013 FRS? I've had trouble finding spec sheets to compare the two, and calling a Toyota dealership was less than helpful. Any instruction or advice is much appreciated.
Thank you!
zrimmi is offline   Reply With Quote
Old 03-22-2018, 07:57 PM   #2
NRXRaptor
Pretty sure this exact thread has been done before, but yes you can. Steps will be the same, but just contact a toyota dealer instead of a subaru one blah blah blah. You'll have to figure out wiring for turn signals, but if you don't want to bother with that any auto shop that does custom work should be comfortable doing it for you
[ame="https://www.youtube.com/watch?v=eix30PHt2mM&t=1s&index=46&list=WL"]2017 Bumper Conversion on my 2016 BRZ - YouTube[/ame]
NRXRaptor is offline   Reply With Quote
Old 04-01-2018, 12:38 AM   #3
Vincenttam
WtsTofu
Vincenttam's Avatar
Drives: Ultramarine fr-s
Assuming you have the bumper and all the random bezels, the only thing you need to swap out and in for is the new headlight bracket. The newer one uses 1 more tab than the old one. Also, the newer bumper doesn't use a parking light anymore. All turn signals are built into the headlight. So you should probably looking into getting some turn signals in your headlight, or risk everyone haitng you when you yield to turn.
ig:Vinshiin
Vincenttam is offline   Reply With Quote
2013 fr-s, 2018 86, front bumper, oem
MY 17 86 to BRZ Bumper swap Darkrune Southeast 0 06-11-2017 12:00 AM
Looking to Swap OEM Front bumper for BRZ OEM Bumper Easy Mid-Atlantic 0 05-26-2015 03:44 AM
anyone want a BRZ bumper? --Dark Grey front bumper swap Charlotte NC IroncladBRX Southeast 0 04-20-2014 09:18 PM
Swap my BRZ front bumper for your FR-S bumper (GBS/ultramarine) wulfgang Exterior Parts (Aero, Lighting, Etc.) 8 11-26-2013 06:48 PM
