Old 03-21-2018, 08:47 PM   #1
milkydude12
milkydude12's Avatar
Drives: none
Toyota 86 2017 special edition Head Unit swap?
Hey, so im thinking of swapping out my stock head unit for this 8 core android head unit (This will be my first mod that requires me to tinker, my prev mod, if you can call it that was my OpenFlash Tablet):
Head Unit: https://www.seicane.com/double-din-a...1afc51c7c6ad26
Steering wheel controller add-on: https://www.amazon.ca/Axxess-AX-TOY2...ss+AX-TOY28SWC
Power converter (Idk if I actually need this, can someone tell me?): https://www.amazon.com/DROK-Waterpro...c07de50dbe70ad
My questions are, will this work with my stock steering wheel's volume controls? Will this work with my stock backup camera? Do I need the extra dongle for radio to work?
(https://www.seicane.com/high-quality...l-antenna-sc19) and do I actually need the power converter in a Canadian Special Edition 2017 Toyota 86? (If I need the power converter, where can I put it? Behind the Head Unit?)
Thanks
milkydude12 is offline   Reply With Quote
Old 03-22-2018, 11:02 AM   #2
el-guapin
el-guapin's Avatar
Drives: 1949 UFO
You gonna need this one to retain the OEM camera: AX-TOYCAM3-6V
Its the 24-pin connector. It comes with the 12v-6v converter so you drop the DROK unit. Yes you need a converter as the OEM camera is 6v. You also gonna need to a wire to pin 2 on the 28 pin connector(AX-TOY28SWC) for the reverse signal and one to pin 17 for the speed signal. Don't forget the antenna and USB adaptors!
el-guapin is offline   Reply With Quote
2017 Toyota 86 head unit help..... PetrolioBenzina Electronics | Audio | NAV | Infotainment 77 02-03-2018 01:55 AM
Toyota 86 2017 special edition HAC (Hill Assist Control) milkydude12 Scion FR-S / Toyota 86 GT86 General Forum 32 12-12-2017 11:10 PM
FS 2017 Toyota 86 860 special edition rim+tire(Set of 4) kdyg123456 Wheels and Tires 2 09-26-2017 04:51 PM
2017 toyota 86 head unit is pissing me off Cosmo Kramer Electronics | Audio | NAV | Infotainment 15 03-20-2017 04:44 PM
2017 Toyota 86 head unit help..... PetrolioBenzina Electronics | Audio | NAV | Infotainment 0 10-16-2016 09:01 PM
