Old 03-21-2018, 08:33 PM   #1
ragnarokfps
Drives: 2016 BRZ Series.HyperBlue
VSC Sport and Trac Off don't work
I don't have a check engine light or any other warning lights, and I'm not sure what the issue is. Anyone have any ideas?
ragnarokfps is offline   Reply With Quote
Old 03-22-2018, 12:30 AM   #2
febrz
Drives: silver brz 2013 lmtd
Is it that the VSC Sport and Trac Off, won't turn off, or won't turn on?
You'd need to give more information. Is it just not notifying you that it's off?
Or you feel no difference driving it after pushing the buttons?
febrz is offline   Reply With Quote
Old 03-22-2018, 10:23 AM   #3
ragnarokfps
I hit the buttons and lights don't appear on the gauge cluster as they should. I believe the traction control is set to on, I've tried drifting and it inhibits rear wheel spin still. Maybe the lights in the gauge are busted, I'll have to try it as though the lights just don't work and see what happens. Hold for 5 seconds.. you know.
Old 03-22-2018, 10:34 AM   #4
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Are you pushing the buttons at low speed or fully stopped?
Current DD: M235i
8RZ is offline   Reply With Quote
Old 03-22-2018, 10:37 AM   #5
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
You need to HOLD just the TRAC OFF button down for 3 full seconds. The two lights you should be getting are both yellow. They will be located just to the left of the Temperature and Fuel gauge. The top one should say "TRAC OFF" and the bottom one should have a symbol of a car on some squiggly lines and the word OFF underneath it. If you have one yellow and one green light, then you haven't done it properly, and you're only in VSC Sport mode, which I find to be rather pointless.
To engage that full-off mode, you don't have to be stopped, or moving slowly. You can do it at any speed. If you have both yellow lights on, and it's still stepping in, then something is wrong with the car.
EDIT: To clarify, after reading your post again. VSC Sport Mode WILL still exert a lot of control over the car. It is universally known to be pretty over-bearing. If you're really trying to hoon the car, you need to do what I stated above. VSC Sport Mode often doesn't allow you to do much of anything before stepping in, which is why they revised it to a Track Mode with slightly increased limits on the refreshed 2017 cars.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
The Following User Says Thank You to Stang70Fastback For This Useful Post:
Ganthrithor (03-29-2018)
Old 03-22-2018, 11:21 AM   #6
extrashaky
Drives: 2014 BRZ Limited
I'm not sure it's a good idea to help this individual drift his car.
The Following 9 Users Say Thank You to extrashaky For This Useful Post:
bkharmony (03-22-2018), finch1750 (03-22-2018), Ganthrithor (03-29-2018), j3rf (03-29-2018), pinoy_dorifto (03-22-2018), Tcoat (03-22-2018), tCsonfrs (04-11-2018), Tristor (03-30-2018), uppitypanda (03-22-2018)
Old 03-22-2018, 01:13 PM   #7
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Especially if they can't figure out how to turn off TC via buttons or pedal dance by themselves
The Following 2 Users Say Thank You to finch1750 For This Useful Post:
pinoy_dorifto (03-22-2018), Tristor (03-30-2018)
Old 03-22-2018, 01:38 PM   #8
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
Well when I bought this car I never had any vehicle with TSC, I had to google how to turn it off in order to rip my first donut.
Trueweltall is offline   Reply With Quote
The Following User Says Thank You to Trueweltall For This Useful Post:
Leonardo (03-22-2018)
Old 03-22-2018, 01:41 PM   #9
Stang70Fastback
A.K.A. Starlord
Your car comes with instructions that explain, in great detail, how every single function in the car works. No Googling necessary!
The Following 4 Users Say Thank You to Stang70Fastback For This Useful Post:
Ganthrithor (03-29-2018), Tcoat (03-22-2018), tCsonfrs (04-11-2018), Tristor (03-30-2018)
Old 03-22-2018, 01:45 PM   #10
Leonardo
Country Boy 4 Life
Leonardo's Avatar
OEM Manual - TL;DR
But, a 30 second google search showed me the way back in 2012...
I LIKE TIRES!
Old 03-22-2018, 01:47 PM   #11
Ganthrithor (03-29-2018), Leonardo (03-22-2018), Tristor (03-30-2018)
Old 03-22-2018, 02:37 PM   #12
finch1750
finch1750's Avatar
Thats my point. If you cant use Google or read the manual I dont have high hopes
bkharmony (03-22-2018), Tristor (03-30-2018)
Old 03-22-2018, 02:38 PM   #13
tomm.brz
Drives: brz 2017 hksv2
it s not true what you're saying, to engage TRC full off mode you need to be at less than 49-50 km/h (30-31 mph) otherwise nothing happens
Track (VSC) mode yes, will do at any speed
The Following User Says Thank You to tomm.brz For This Useful Post:
Tcoat (03-22-2018)
Old 03-22-2018, 05:09 PM   #14
Stang70Fastback
A.K.A. Starlord
No. What I said was correct. Perhaps I wasn't clear. When I said "that full-off mode" I was referring to the mode I had just described in my post, which is accessible by holding the TRAC OFF button down for 3 full seconds, to fully defeat both driver aids. That mode can be accessed at ANY speed.
So, to say it again more clearly: You can hold down the TRAC OFF button for 3 seconds at ANY speed to fully disable traction and stability control.
What you are referring to is just the normal "TRAC OFF" mode accessed by only briefly pressing the TRAC OFF button. This mode is only accessible up to ~30 MPH because it isn't designed to be used above 30 MPH. It is only meant to be used in slick conditions/when you want a bit of wheelspin off the line.
The Following 3 Users Say Thank You to Stang70Fastback For This Useful Post:
Ganthrithor (03-29-2018), tCsonfrs (04-11-2018), Ultramaroon (04-04-2018)
Vsc sport mode and trac off RWD-boxer Engine, Exhaust, Transmission 94 02-25-2020 09:23 PM
WORK Emotion Wheels ** Winter Promotion || Free WORK Lugs or WORK Caps ** RavSpec Wheels and Tires 18 12-10-2013 05:19 PM
VSC Sport, Trac Off, Both Off - Which do you use for normal driving? pinoyplaya BRZ First-Gen (2012+) — General Topics 100 08-28-2012 02:24 AM
Question about VSC and Trac? Liquidsnake Scion FR-S / Toyota 86 GT86 General Forum 1 04-23-2012 11:24 PM
