Old 03-20-2018, 10:07 AM   #1
Slade
Slade's Avatar
Drives: 14 Limited BRZ
Would anyone recommend this Head Unit or something similar?
https://www.crutchfield.com/p_070AC6...CPM6628BT.html
I'm fed up with the factory GPS and would love to use my iPhones navigation. I see this Head Unit has Apple Car play which is awesome and my research tells me this is a direct plug and play swap? The only thing is I have never heard of this brand before. It could just be my ignorance however. Please inform me or even give me something better that you guys would recommend. Thanks!
Slade is offline   Reply With Quote
Old 03-20-2018, 10:48 AM   #2
Chimera
Drives: FRS
definitely not a direct plug and play, that has standard aftermarket antenna hookup and standard wiring to be mated with a aftermarket harness adapter, metra or scoche are common brands.
on the audio side of things its got a 10 band instead of 13 band eq, and 14w rms instead of 22w rms internal amp that you find on some of the other brands
I wouldn't choose this personally over the Sony XAV-AX100, unless you are planning amps and other things and the cheaper internals on the axxera don't matter. and yes I realize that the Sony also only has 10 band eq, which isn't bad, but you can find 13 on some units.
The Following 2 Users Say Thank You to Chimera For This Useful Post:
Slade (03-20-2018), Tcoat (03-21-2018)
Old 03-20-2018, 10:54 AM   #3
Slade
Slade's Avatar
Hey I like the one you linked me, I like that it has a built in micrphone, and apple car play and android auto. Its more expensive but thats fine. Thanks! Hows install for that one?
The Following User Says Thank You to Slade For This Useful Post:
Chimera (03-20-2018)
Old 03-20-2018, 11:22 AM   #4
Chimera
Drives: FRS
I have not personally installed it, but it looks the same as any other aftermarket unit. You will need a few things in addition to the unit, an antenna adapter, metra harness, usb adapter or replacement for the aux/usb port, faceplate adapter, (I think theirs a sonic kit that has harness and faceplates together).
a bit of searching should lead you to finding the list of thins you need but if you need more help let us (the forum at large) know, and we'll point you in the right directions.
Old 03-21-2018, 08:54 AM   #5
ncted
Drives: 2017 BRZ Limited
In my experience, built-in mics are not good. Not saying this one wouldn't be fine, but experience would make me stay away.
ncted is offline   Reply With Quote
The Following 2 Users Say Thank You to ncted For This Useful Post:
Chimera (03-21-2018), Slade (09-12-2018)
For Sale: Stock BeSpoke Premium Audio head unit with NAV unit Glok24 Audio/Visual, Electronics, Infotainment, NAV 13 07-22-2018 12:34 AM
FS: Like new OEM BRZ head unit w/ nav inositle Audio/Visual, Electronics, Infotainment, NAV 2 08-26-2015 08:38 PM
Anybody know ... what head unit this is? chaoskaze Electronics | Audio | NAV | Infotainment 3 12-21-2014 06:44 PM
BRZ Nav Head Unit Sojhinn Audio/Visual, Electronics, Infotainment, NAV 16 11-03-2013 06:02 PM
BRZ Head Unit RedRocket Audio/Visual, Electronics, Infotainment, NAV 2 06-25-2013 10:21 PM
