Old 03-19-2018, 06:25 PM   #1
btan219
Drives: DGM 15' BRZ Limited
Daily Driver: Do you get wheel alignment after X miles, X years, or when not straight
Just wondering how often wheel alignments should be done for a daily driver, no tracks or anything. Is it after X miles, X years, or when the car doesn't seem to drive straight anymore, or when uneven tire wear?
If the car still drives straight and tire wear is even, is there any reason to get a wheel alignment, even if you haven't done one in 2-3 years?
btan219 is offline   Reply With Quote
Old 03-19-2018, 06:27 PM   #2
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Originally Posted by btan219 View Post
Just wondering how often wheel alignments should be done for a daily driver, no tracks or anything. Is it after X miles, X years, or when the car doesn't seem to drive straight anymore?
If something feels wrong, hit something, notice strange tire wear, or get new tires.
Old 03-19-2018, 06:29 PM   #3
btan219
thanks for the quick reply! replied faster than i could add an edit to my original post
Old 03-19-2018, 06:30 PM   #4
Sapphireho
Famous Potatoes
Sapphireho's Avatar
I'm bored at work.
Old 03-19-2018, 09:16 PM   #5
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Think of it like a repair (unless you just want to change the alignment to your own settings)
Old 03-20-2018, 07:49 AM   #6
reeves
I didn't get my first alignment done until almost 5 yrs after I bought it, and 75K+ miles (no tracking or autoX either). The tires wore evenly & steering wheel didn't shake at highway speeds, so I didn't think there was a need for it. Only once the car started "drifting" ever so slightly to the right when the steering wheel was centered did I get the alignment checked.
reeves is offline   Reply With Quote
Old 03-21-2018, 12:25 PM   #7
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
I would do mine whenever it doesn't drive straight or I notice uneven wear when I rotate the tires.
Old 03-21-2018, 12:29 PM   #8
Sapphireho
Famous Potatoes
Sapphireho's Avatar
That would be wheel balance. steering wheel shake=have your tires re-balanced.
Old 03-21-2018, 02:41 PM   #9
Racecomp Engineering
We basically get alignments right off the showroom floor. After that, settings should hold for a long time for MOST people, depending on how the car is used and how adjustments are made. Camber bolts can slip depending on how they're installed, the rear toe arm isn't perfect, and sometimes you just hit a big ass pothole.
IMO it's a good idea to check yearly if your car is tracked/autocrossed often OR driven on crap roads. A camber gauge and toe plates aren't too expensive. That's all you need to check an alignment. Alternatively, an alignment shop shouldn't charge much to just put it up on the rack.
Overkill for most people, but I'm anal about alignments.
- Andrew
Old 03-21-2018, 07:28 PM   #10
churchx
churchx's Avatar
Drives: 2014 GT86
Racecomp Engineering: and another reason i can think of to change alignment more often - if car is tracked both in (cold) winter & summer, as ideal alignment is different in low-grip situation.
Old 03-23-2018, 12:08 AM   #11
BuzzR
Drives: 2013 BRZ Limited
I will have had my 2013 BRZ exactly four years on April 1st, and I just had my first alignment done today while having new tires put on my Limited.
The guy said it was slightly off, but it's perfect now. I probably didn't need to do it, but I wanted it perfect for the new tires.
I would say not to worry about it unless you've hit some really bad bumps or the car is noticeably drifting.
BuzzR is offline   Reply With Quote
Setting Up Alignment for Daily Use Lust Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 11-22-2018 03:12 PM
Two years and 20k miles... misooscar Scion FR-S / Toyota 86 GT86 General Forum 22 03-09-2016 11:16 PM
Two years, 70k miles Keoki Scion FR-S / Toyota 86 GT86 General Forum 41 07-18-2015 05:01 PM
The quickest road car Car and Driver tested in our 59 years robwbright Other Vehicles & General Automotive Discussions 24 05-19-2014 10:01 PM
Good wheel/tire set up for daily driver Oburn Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 07-10-2013 02:21 PM
