Old 03-19-2018, 02:41 PM   #1
Qwimby1
Drives: 14 FRS Monogram, 05 Mazdasped Miata
Gauge question
I just picked up a '14 Monogram edition which I'll set up for track. First concern is for oil pressure and temp gauges. I haven't had time to pull the intake filter box off, but I'm told there are sending units for both underneath it. Is that so? Also, I plan to put in a K&N filter, but wonder if there's any real gain from an aftermarket unit.
Thanks
Qwimby1 is offline   Reply With Quote
Old 03-19-2018, 03:59 PM   #2
humfrz
Thanks
Oh, some feel that there is some power gain from a free-er flowing air filter ..... how much depends on whether or not you put the sticker on .....
humfrz
Old 03-19-2018, 04:08 PM   #3
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
With the K&N drop in filter there will be a gain. With their Typhoon intake you will gain more induction noise than power(without tune), you're also going to need to tune it and wash off the oil from the filter so it doesn't mess up the MAF. You also have less space if you decide to use a sandwich plate for sensors.
I would recommend sticking with a drop in filter instead of going the route I went.
You will also need to use the sending units of the gauges you buy regardless of what it has from the factory, sure there are locations you can tap into or save the headache and get a sandwich plate.
Trueweltall is offline   Reply With Quote
Old 03-19-2018, 04:16 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Thanks
There are sending units for temp and pressure but I don't believe any aftermarket gauge is compatible with them that I have seen. Most gauges come with sending units but you would need to buy the adapters to hook them up. I am pulling my pressure from the factory location, and temp from a port next to the a/c compressor.
I would also recommend going with a separate oil and temp gauge. I went with the Innovate dual gauge and the temp is hard to read since it is represented as a graph.
Old 03-19-2018, 04:17 PM   #5
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Under the air box next to the TB there's a port that you can tap into. http://www.ft86club.com/forums/showthread.php?t=125350
I have my sending unit in that port, but I had to make an extension for it because of my intake getting in the way. A lot of people use a sandwich plate since the oil filter is right there practically poking you in the eye.
DSportMag did a round up with tuned and untuned dyno numbers of a BUNCH of different intakes. Make up your own mind if it's worth it.
Fuel Pressure Gauge Question Strife26 Engine, Exhaust, Transmission 19 12-20-2017 11:34 PM
Prosport Oil Gauge Question guybo Electronics | Audio | NAV | Infotainment 3 08-25-2017 06:56 AM
Question regarding installing Defi gauge nichiolas DIY (Do-It-Yourself) Guides 2 07-13-2016 12:42 PM
Frs temperature gauge question Young_makaveli Engine, Exhaust, Transmission 11 01-03-2014 06:25 PM
P3 Gauge Question jjkerr626 Software Tuning 1 01-01-2014 02:41 AM
