Old 03-16-2018, 11:37 PM   #1
Sikku
Drives: SWP 13' BRZ
Tein Coilovers Rear Side Difficulties
Hey guys, I am pretty new to the forum and to suspension changes so bear with me. A friend and I installed my new coilovers. The front two were easy, the rear passenger side was also easy, however the rear driver said is extremely difficult for us.
The problem is that we cannot align the rear side with the rear trail arm or the rear lateral trail arm (I think its called one of these two) with the nuts and bolts after we installed the coilover. This is the arm that is closest to the wheel on the very side. This headache all started when we took out and removed the entire RCA on the driver side and the arm beside the rotor (rear lateral or trail arm). We know we didnt have to take out the entire RCA and the other arm but we did for clearance to get the factory bolts out. It seems the rotor is not aligned or out of place because the nuts and bolts are off. It doesn't make sense because all we did is remove the RCA and the other arm. It is around 1/4 inch off the factory holes. Does anybody have any idea how we align everything correctly to the proper holes? Is the rotor out of place? What did we ddo wrong?
We took the RCA off and the rear lateral arm or trail arm and worked backwards and its still off.
Sikku is offline   Reply With Quote
Old 03-17-2018, 12:51 AM   #2
norcalpb
norcalpb's Avatar
The left green arrow is the trailing arm, the right green arrow is the LCA (Lower control arm), the white line is the toe arm (sometimes called a lateral link), and the yellow arrow is the upper wishbone (sometimes called an upper A arm).
You should only have to disconnect 3 bolts (hub bolt, shock bolt, endlinks bolt) on the LCA to install the rear assembly, the entire thing drops down and you can put a jack under the LCA to lift it into place with everything installed.
Old 03-17-2018, 02:04 AM   #3
Sikku
Drives: SWP 13' BRZ
Yes! That image is perfect! the left green arrow is the assembly that does not align correctly when attempting to put it back in place. I know we did not need to remove it but we did. But just because we removed the lateral link doesn't mean we can't put it back on right? We just don't know why it doesn't want to align with the holes.
Old 03-17-2018, 02:36 AM   #4
norcalpb
norcalpb's Avatar
Sorry the left green arrow is actually the trailing arm. I would disconnect the 3 outer bolts on the LCA, let the LCA hang straight down, and then try to move the hub to its correct location to fit the trailing arm. Take out the rear Tein coils just until you get the trailing arms installed.
The Following User Says Thank You to norcalpb For This Useful Post:
strat61caster (03-17-2018)
Old 03-17-2018, 02:51 AM   #5
Sikku
Drives: SWP 13' BRZ
We tried to move the hub to the correct location but it only moves up and down. We need to move it left or right. We completely removed the LCA and tried to align it and no luck. We reinstalled the LCA, and attempted to realign the trailing arm and no luck. The hub seems to be in an incorrect position compared to the other side though. How can this be?
Thank you for your responses btw. I will again try to do as you say here shortly.
Old 03-17-2018, 08:00 AM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Install the trailing arm onto the hub. The LCA is easier to line up. You will need to lift up on the hub while trying to fit the lca, it should pivot some. With it dropped all the way down the toe arm is tugging at the front and changing the alignment.
Old 03-17-2018, 10:04 AM   #7
ZionsWrath
Thanks
ZionsWrath's Avatar
Try using a just to lift things up a bit.
If you need to bring them down more have your friend gently add weight with his foot to the hub.
It's a fun game getting it in the hole
The Following User Says Thank You to ZionsWrath For This Useful Post:
Old 03-17-2018, 03:08 PM   #8
Sikku
Drives: SWP 13' BRZ
So we lifted it up but the arm does not want to go on. It seems its off a little. Here is a picture of how it is. We tried moving the wheel hub but it only gives way up and down. It seems we need to shift it to the left somehow. Any other suggestion guys?
Old 03-17-2018, 03:29 PM   #9
strat61caster
strat61caster's Avatar
Is the parking brake released?
ineedyourdiddly
Old 03-17-2018, 03:35 PM   #10
Sikku
Drives: SWP 13' BRZ
HOLY THAT WORKED. I feel so stupid. Thank you very much!!!! Life learning experience! Thank you guys for the responses.
The Following User Says Thank You to Sikku For This Useful Post:
Tein coilovers irod1021 Brakes, Suspension, Chassis 4 01-14-2018 09:48 PM
Coilovers Coilovers, Coilovers: Tein, KW, BC, D2, Cusco, Eibach + more FREE SHIPPING! No Limit Motorsport Brakes, Suspension, Chassis 204 05-26-2017 12:09 PM
NEW Tein Street Flex Coilovers and SPL Rear Control Arms sb Brakes, Suspension, Chassis 7 03-05-2016 06:20 PM
Coilovers. GC vs Tein vs RS*R vs KW etc. Re~Mix Suspension | Chassis | Brakes -- Sponsored by 949 Racing 54 09-26-2013 04:24 PM
difficulties finding Perrin 3" cat-back jonbonazza Engine, Exhaust, Transmission 2 05-27-2013 02:34 PM
