Old 03-14-2018, 05:13 PM   #1
Prax
Drives: 2017 BRZ Inazuma Edition
720Form GTF1 Brembo Brakes Fitment
Hey all,
Does anyone have the 17x9 720Form RAI GTF1 (+35) fitting with the Brembo BBK?
My 2017 Series.Yellow needs some track wheels and rubber. I'm running -1.7 camber on the front with whiteline bolts for now.
I haven't found much online on the fitment for the BRZ with BBK.
Thank you.
Sent from my Nexus 6 using Tapatalk
Prax is offline   Reply With Quote
Old 03-15-2018, 09:50 PM   #2
Misfire
Misfire's Avatar
Drives: 2017 Series.Yellow, 2005 LGT wagon
I was just about to make a thread about this.
I thought I read that 17x9s don't fit, but I couldn't find the thread again. Apparently 18x9 GTF2s don't fit, as seen here:
Originally Posted by Lightened View Post
Apparently the OEM Subaru Performance Package Brembo's DO NOT fit with the GTF2 18x9 without a small (3-5mm) spacer. Can someone confirm?
This must also be the case for the 17x8 and 17x9 GTF1. Again, can someone confirm?
The Wilwood BBK will work since they fit with stock OEM wheels rims.
I am interested in 17x8 GTF1s, but I've not seen a confirmation anywhere. I do believe I've found a proper template from an aftermarket Brembo kit for WRXs that is very close to the PP Brembos, if not the same. Found here. The aftermarket Brembo kit specific to the BRZ does not fit the PP wheels!
Would any GTF1 owners be kind enough to print the template and test fit it to their wheels?
Clarification: My images are of the template in Performance Pack wheels.
Misfire is offline   Reply With Quote
Old 03-15-2018, 10:16 PM   #3
Teseo
Drives: frs
I would add 5mm spacers to be on safe side
Old 03-15-2018, 10:25 PM   #4
Misfire
Misfire's Avatar
To the OEM Performance Pack wheels and Brembos? That template has the same clearance as OEM. I want to know if that template will fit into the wheels I want.
Old 03-18-2018, 10:27 AM   #5
Misfire
Misfire's Avatar
@Prax Well, sad face , stumbled across this:
Originally Posted by BRZ FAMILY FUN View Post
I really like the 720 Form GTF-1, but unfortunately they don't clear the Brembos on the Performance Package. I found this out after having CARID send a 17X8 and a 17x9 both with a +35 offset.
The Following User Says Thank You to Misfire For This Useful Post:
Prax (03-18-2018)
Old 03-18-2018, 11:10 AM   #6
Jordanwolf
Rice King
Jordanwolf's Avatar
If only I had Brembo...
Glorious Honda.
Jordanwolf is offline   Reply With Quote
Old 06-09-2018, 12:37 PM   #7
babykwiss
Drives: Scion FRS
I just put on my gtf1 17x9 and it would not clear. I bought a 3 mill spacer
babykwiss is offline   Reply With Quote
720Form GTF1 17x8 +35 BattleSnake Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 04-26-2018 09:34 AM
720Form GTF1 17x9 +35 DarkestBuddha Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 47 10-08-2017 03:21 AM
WTB: 720Form GTF1 Tectoniic Want-To-Buy Requests 0 02-02-2016 11:21 AM
720Form GTF1 17x8.0 +35 Talus1 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 01-02-2016 01:28 PM
17x9 +35 720Form GTF1 installed! BRZZZZZZZZZZ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 06-27-2014 07:12 PM
