Drives: 2017 Subaru BRZ Limited
OpenFlash Tablet VS EcuTek tuning
i'm new at this software tuning stuff. i had my mind made up to purchase an OpenFlash tablet to for stage1 (for now) and possibly stage2 tuning after i get a catless header, until i saw the thread about EcuTek. from a nutshell both gain similar numbers for stage 1, OFT you can do it on your own, whereas EcuTek you can take to a tuning shop and do it. which route is more reliable? any pros and cons for both of them? this is strictly for stage1 and stage2 tuning, nothing crazy, no FI.
Drives: frs
1st
The Dictater
Drives: '13 Red Scion FRS
http://www.ft86club.com/forums/showthread.php?t=106068
Read through that if you haven't already. I started down this path this time last year and went with OFT if that helps. |
^^^thanks. i'm still leaning toward OFT, however, i've read for 2017 model we were have to send OpenFlash the factory ECU file and then wait for them to send you the new tune for 2017 model specifically. i understand the reason behind that since the manual equipped 2017 models have different manifolds, but mine is an auto, do i still wait for the new tune or just use the current one comes with the tablet?
#5 | |
The Dictater
why is it ECUTek tuning packages for stage 1 and 2 are substantially more expensive than OFT versions? does ECUTek tuning allows you to revert back to stock ROM like OFT does? lastly, OFT tuning is pretty straight forward according to youtube videos, how difficult is it for ECUTek? do i need a shop to do it?
#7 | |
Same level of skill requored to tune NA car if you ise ecutek or oft. On na car no great advanrage usong ecutek unless yo want multiple maps or fanch launch flat foot sgift auto blip fwatures. If you jist want basic na a tune pick the cheaper option Oft comes with basic NA tunes as part of package Ecutek does not come with ant tunes other than stock roms Both systems can flash back to stock if needed But ecutek lcience will remain in ecu once you have used ecutek and that licience is detectable. Its possible to remove the ecutek licience but then you would need to purchased another one to tune ecutek again and they are $300 Ecutek has more features but if you dont use or need them then its not worth thte money |
^^^ thank you for the reply. Can I use OFT for stage 1 tune now and then change it to stage 2 after I get the catless header? Do I need to flash my car back to oem first then do the stage 2 tuning or just a straight upgrade from stage 1 to stage 2?
The Dictater
The OFT marries to your car, then you can load any tune you want. Flashing from stock to stage1 is the same process as flashing from stage1 to stage2. It just replaces the tune file on the the ECU with another one.
#10 | |
#11 |
if i plan to go FI eventually, is does Ecutek a better buy than OFT? i have my new OFT about to delivered to me this week, but still contemplating on returning it for Ecutek
#12 | |
If your car is a 2017 oft doesnt have flex option or the overboost cut for those cars yet , and it might be a way off So for 2017+ FI you will need ecutek in most cases |
#14 | |
| openflash tablet vs ecutek tune | brz23 | Software Tuning | 104 | 07-28-2020 04:36 PM |
| Need An openflash tablet for brz when tuning? | mr.brz1234 | BRZ First-Gen (2012+) — General Topics | 1 | 10-25-2017 07:02 PM |
| FS: Openflash Tuning Tablet (OFT) socal | andy86 | Engine, Exhaust, Bolt-Ons | 1 | 09-06-2017 03:32 AM |
| [OFT] OPENFLASH TABLET: Tuning flexibility in one convenient package | Garrett@Openflash | Engine, Exhaust, Bolt-Ons | 62 | 07-10-2015 02:40 AM |
| OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) | Rombinhood@OpenFlash | Software Tuning | 237 | 02-10-2014 03:35 PM |
