Old 03-06-2018, 03:30 PM   #1
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
OEM Front pipe to 3' Greddy RS Catback Exhaust
What's up guys. I have searched the forums but i cannot find anything in regards to this. Has anyone mounted a 3 inch catback to the stock oem frontpipe? If so will this work http://www.grimmspeed.com/stock-dp-a...dapter-subaru/ . Thanks in advance
Old 03-06-2018, 04:37 PM   #2
jjorgen
jjorgen's Avatar
Drives: 2016 Scion FR-S
I do not have the Greddy RS Cat back but I have the Greddy EVO GT cat back which is also the 3 inch. when I went to install it, it came with a 3inch gasket for the connection to the stock front pipe, so I simply removed the donut gasket from the front pipe and made sure the surface on the front pipe was smooth and then used the gasket with a little high temp RTV. I had absolutely no leaks at all I just made sure when I did it the first time the bolts they supplied were nice and tight. Hope this helps.
jjorgen is offline   Reply With Quote
The Following User Says Thank You to jjorgen For This Useful Post:
NyC Zn6 (03-06-2018)
Old 03-06-2018, 05:26 PM   #3
CHMBRZ
Drives: 2016 Subaru BRZ Limited
Ran the Tomei 80r in stock fp before no problems.
CHMBRZ is offline   Reply With Quote
The Following User Says Thank You to CHMBRZ For This Useful Post:
Old 03-06-2018, 07:24 PM   #4
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
I have as well, so I can verify this.
JimmyMac is offline   Reply With Quote
The Following User Says Thank You to JimmyMac For This Useful Post:
CHMBRZ (03-07-2018)
Old 03-11-2018, 12:58 PM   #5
Ashikabi
Ashikabi's Avatar
I had the GReddy Evo GT and used a flat ring gasket between the 2 instead of OEM donut. Beware, once you get UEL, you may drone and cold start will be loud as fuck
Old 03-12-2018, 12:13 AM   #6
thecarfilmer
IG: @nickwiththefrs
thecarfilmer's Avatar
Drives: 2016 Scion FR-S Halo
I had to get new bolts and nuts for mine. The oem spring bolts wont go through.
thecarfilmer is offline   Reply With Quote
Old 03-12-2018, 10:53 AM   #7
NyC Zn6
NyC Zn6's Avatar
Would you happen to remember the sizes of the bolts you purchased?
WTB: UEL Headers / Uncatted front pipe / Catback exhaust Mikyt3 Australia Classifieds 0 08-07-2017 05:47 AM
Tanabe front pipe and medalion catback exhaust kinryu Engine, Exhaust, Bolt-Ons 0 08-28-2014 06:52 PM
shop/local installing MXP exhaust catback & front pipe jgonx213 Southern California 7 11-06-2013 03:55 AM
MXP SP series catback exhaust & catless race front pipe No Limit Motorsport Engine, Exhaust, Bolt-Ons 17 11-12-2012 09:47 PM
