Old 03-01-2018, 09:10 AM   #1
Weigaldo
Weigaldo's Avatar
Drives: 2016 Steel AT FRS
OFT E85: Set it and forget it?
I apologize if this question has already been asked, but I didn't see anything specific to E85... I know in the past it has been said you can pretty much run the OFT Stg1 or 2 91oct tunes and not worry about monitoring/tweaking (vs running 93oct tunes). My header back exhaust with OFT Stg2+ has been running with good trims and 1 IAM since around September. Would I be able to run the OFT Stg2 E85 tune (during Spring and Summer) without monitoring/tweaking?
Weigaldo is offline   Reply With Quote
Old 03-01-2018, 01:50 PM   #2
steve99
Biggest issue with running E85 in usa is wide variation in ethanol content, some "E85" can be as low as 50% ethanol.
you would need to monitor afr and fuel trims or measure ethanol content
Don't forget to do this! Cone_killer Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 12 06-20-2017 11:55 PM
Never forget 5/25/77 mav1178 Off-Topic Lounge [WARNING: NO POLITICS] 2 05-27-2016 10:38 PM
Do you guys forget what parts you have? Ashikabi Off-Topic Lounge [WARNING: NO POLITICS] 32 02-15-2016 08:20 AM
Forget all the armrest you have seen thus far, this is what we need! chenshuo Cosmetic Modification (Interior/Exterior/Lighting) 10 02-24-2013 09:11 PM
