Drives: Scion FR-S
P0461 code
Been having this check engine line for the longest . I know what the code means but idk how to fix it . Has anyone found a solution or any suggestions and I always clear the code with the obd so it won’t annoy me.
Most likely the fuel level sender in tank,
Huge E85 fan!
Drives: 2016 Scion FRS
IME a bad sending unit is the first step in your fuel pump going bad. It could be something else (I had a OBD2 port reader with a connection issue that would cause this CEL along with a CANBUS communication error), but if the car is under warranty, get it in and tested. If not, I'd run it until it dies- you can run with a bad sending unit for a LONG time and you'll be fine, it doesn't always mean that the fuel pump is screwed. Don't trust the fuel gauge, start using the trip odo instead
| Another CEL code | whitefrs | Forced Induction | 20 | 11-27-2019 11:27 AM |
| P0461 code | H214M | Issues | Warranty | Recalls / TSB | 7 | 01-22-2018 01:28 PM |
| p0462 fuel level sensor code. anyone else ran into this code | georgiafrsguy | Engine, Exhaust, Transmission | 1 | 02-28-2017 08:28 PM |
| Lean Code and 02 Code diagnostics. | Kiske | Engine, Exhaust, Transmission | 12 | 04-28-2016 10:19 PM |
| CEL code | ChandlerSwyng | Issues | Warranty | Recalls / TSB | 2 | 04-08-2014 01:27 AM |
