Old 02-19-2018, 07:03 PM   #1
B 86
Drives: Limited WRB Subaru BRZ
Rays Gram Lights 57xtreme 18x8.5 +42 (Face 2)
Hey all! I've been searching for pictures of these wheels and have come across very few. In the wheel directory there has been talk of this specific size and offset but no dedicated post for them. 18x8.5 +42 (Face 2) I believe were made to have a similar concave face as the 18x9.5 +40. I am looking into getting these but are unsure of how concave the 8.5 Face 2 actually is compared to the 9.5s. If anyone has this setup or could lead me in the right direction, it would be greatly appreciated!
B 86 is offline   Reply With Quote
Old 02-19-2018, 09:50 PM   #2
rt
@rayhere
rt's Avatar
The 18x9.5 +40 is also face 2 so the concavity will be exactly the same. You can confirm this on the Rays website under the "Face Design" section. All the face 2s are the same except for offset/backspacing.
https://www.rayswheels.co.jp/product...wheel=57EX_STD
rt is offline   Reply With Quote
The Following User Says Thank You to rt For This Useful Post:
B 86 (02-19-2018)
Old 02-19-2018, 10:40 PM   #3
B 86
Thank you for the help!
Old 02-23-2018, 12:28 AM   #4
godzuki
godzuki's Avatar
Drives: frs
i posted some pics with these on different tires... check my post history
godzuki is offline   Reply With Quote
The Following User Says Thank You to godzuki For This Useful Post:
B 86 (03-02-2018)
Old 03-01-2018, 11:06 PM   #5
57EW
57EW's Avatar
Drives: Toyota GT86 'GTS'
Hey heres a link to a photo of the set I have
http://www.ft86club.com/forums/showp...&postcount=232
plus heres some more showing the concave
57EW is offline   Reply With Quote
The Following User Says Thank You to 57EW For This Useful Post:
B 86 (03-02-2018)
Old 03-02-2018, 12:09 AM   #6
B 86
Thanks bro! Didn't know the lip protruded so much on different tire set ups, good to know!
Old 03-02-2018, 12:15 AM   #7
B 86
Thanks! Your post on that tread was the reason I started looking into this specific size and offset! I'm planning to stay stock suspension. What are your tire specs and is this picture with you still on stock suspension?
Old 03-02-2018, 01:04 AM   #8
B 86
Originally Posted by ERA View Post
Thanks bro for the help with finding some nice pics of the wheels. Making me want them more and more haha
Old 03-02-2018, 01:10 AM   #9
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
The lips stick out because the tire is undersized (aka stretched) for the wheel width (in this case 235 tire on a 9.5" wide wheel). You generally want to run 245 or larger for a 9.5" wheel to avoid stretch.
Last edited by EndlessAzure; 03-02-2018 at 01:48 AM. Reason: Terminology correction
EndlessAzure is offline   Reply With Quote
The Following User Says Thank You to EndlessAzure For This Useful Post:
B 86 (03-02-2018)
Old 03-02-2018, 01:30 AM   #10
B 86
Originally Posted by EndlessAzure View Post
The lips stick out because the tire is undersized (aka stretched) for the wheel diameter (in this case 235 tire on a 9.5" wide wheel). You generally want to run 245 or larger diameter for a 9.5" wheel to avoid stretch.
Makes sense, thanks bro!
Old 03-02-2018, 08:03 PM   #11
godzuki
godzuki's Avatar
Drives: frs
the lip does protrude a lot on these wheels. some don't mind a little lip sticking out, but it bugged the hell out of me cause it didn't look right. was about to sell mine till i experimented with a few tires and finally found a combination that ended up completely tucking the lip in. even a simple variation (tpc spec vs not) of the same tire size (255/35) on the same model (pilot super sport) made a HUGE difference in the fit of the wheel. (the tpc spec tucked the lip, the other didn't). can't stress this enough as it's caused me a ton of trouble.
B 86 (03-02-2018)
Old 03-02-2018, 08:34 PM   #12
B 86
Thanks, that's really good to know since I'll most likely be getting pss tires as well
Old 03-03-2018, 02:14 AM   #13
RJasonKlein
RJasonKlein's Avatar
They’re great wheels that are hubcentric, strong, affordable, with a fitment specifically for our cars - the only downside is that they’re just a little bit heavy. Here’s my setup consisting of RAYS Gramlights 57Xtreme 18" x 8.5" +42 wheels, Maxxis RC-1 235/40ZR18 tires, and MCS 1WNR single adjustable coilovers on Swift 8K springs all around:
RJasonKlein is offline   Reply With Quote
The Following User Says Thank You to RJasonKlein For This Useful Post:
B 86 (03-03-2018)
Old 03-03-2018, 11:44 AM   #14
B 86
They look great on your car bro! Fitment looks awesome!
The Following User Says Thank You to B 86 For This Useful Post:
RJasonKlein (03-03-2018)
SOLD: Rays Gram Lights 57xtreme 18x9.5 +40 MA Canadian144 Wheels and Tires 5 09-18-2017 09:28 AM
FS: Rays Gram Lights 57Xtreme KRN BRZ Wheels and Tires 16 03-20-2017 03:56 PM
Rays Gram Lights 57Xtreme 18x9.5 +40 Halfscale2130 Wheels and Tires 6 08-21-2016 07:35 PM
Rays Gram Lights 57xtreme 18x8.5 33 Offset w/ Tires Continental Contiseal 235/40/18 guitardecadance Wheels and Tires 0 08-21-2015 01:40 AM
Rays Gram Lights 57Xtreme 19 x 9.5rear quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 08-15-2012 11:50 AM
