Old 02-18-2018, 10:20 PM   #1
Tristor
Tristor's Avatar
Drives: 2017 Subaru BRZ Limited
Where can you buy OE Subaru TPMS sensors?
Howdy,
I just ordered a set of aftermarket wheels and my intention is to install a new set of TPMS sensors in them. My understanding is that Subaru codes the sensors so you can't just use generic TPMS sensors and that the sensors are vehicle-matched. Unfortunately, I don't see the sensors listed on Subaru's parts website, and I haven't had any luck finding them elsewhere either.
I'm pretty sure I can get them from the dealership... but I'm afraid to find out how much that is going to be.
Anyone know of a good source to purchase these or have information otherwise that I can use normal aftermarket 315mhz sensors?
Thanks!
Tristor is offline   Reply With Quote
Old 02-18-2018, 11:06 PM   #2
GrantedTaken
https://www.subarupartsamerica.com/p...iagram=7610165
https://parts.subaru.com/p/Subaru__/...8103CA001.html
https://www.subarupartsdeal.com/part...8103ca001.html
https://subaruonlineparts.com/subaru...ms-p-3941.html
https://www.subarupartsforyou.com/oe...MTY1NSZyPTI%3D
Looks like $80/ea
28103CA001
GrantedTaken is offline   Reply With Quote
Old 02-19-2018, 01:12 AM   #3
Si_Chris
Drives: 2016 ISM BRZ Limited, 2000 Civic SI
Rockauto is the cheapest, $41.79 a piece which includes everything.
http://www.rockauto.com/en/moreinfo....353819&jsn=345
I have these for my winter wheels, these are made by Denso which are identical to the OEM ones. These also work well with no issues using the ATEQ TPMS quickset tool, which is around $120 give or take.
If you do get the ATEQ TPMS quickset tool, you should pull your factory TPMS codes first using the tool via the OBD2 port, and then load them into the software program the tool comes with on a laptop or computer. In the program, you can enter your TPMS codes from the new sensors (which are stamped on the sensors themselves), and essentially you will have two sets of codes in the program at this point. The program then allows you to download the codes onto the tool, and you can program which set of codes you want to your car via the OBD2 port.
Si_Chris is offline   Reply With Quote
Old 02-19-2018, 04:53 AM   #4
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
It's not as easy as getting an extra set of sensors. Originally, I wanted to do what you had in mind.
However under regular circumstances, the car will only be able to recognize one set of 4x sensors at a time: each individual sensor is paired with the ECU.
Of course @GrantedTaken listed the parts and @Si_Chris already mentioned how you can get around that, but it involves getting a 4 more sensors, a TMPS tool, reprogramming, and managing which sensors the ECU actually communicates with every time you swap wheels.
In the end, the expense and extra effort weren't worth it for me. I just took the 4x TPMS on my stock wheels and put them on my aftermarket wheels. I live with the TPMS light when I use the stock wheels.
EndlessAzure is offline   Reply With Quote
Old 02-19-2018, 07:50 AM   #5
Yousend
Drives: 2014 FR-S
I've come to the same conclusion, however I decided to keep my TPMS light on my stock wheels and deal with the TPMS light in the summer. It doesn't bother me to check tire pressure in the summer, but I'd rather not check it in the winter unless I feel something is off.
Yousend is offline   Reply With Quote
Old 02-19-2018, 08:15 AM   #6
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Check Craigslist and FB marketplace, there are often people selling OEM rims with sensors for less than the price of the sensors alone
Old 02-19-2018, 09:17 AM   #7
GrantedTaken
Each TPMS has its own code?
So, you have 4 total codes per set of wheels?
Old 02-19-2018, 03:21 PM   #8
Tristor
Tristor's Avatar
I'm in an area where I will be on summer tires year-round, but my concern was that removing the TPMS sensors from the stock wheels to swap them will likely damage the valvestems. I figured it'd be easier to start with new and then just program them into the car and have done.
I'm intending to sell my stock wheels/tires once I get aftermarkets installed, so I might just be one of those folks selling the wheels for somebody else the harvest the sensors off.
Thanks a ton everyone for the advice in this thread. My wheels are on order and I expect delivery in 8-10 weeks from Japan, so I am going to order the sensors in a few weeks and hopefully I can figure it all out
Old 02-19-2018, 06:00 PM   #9
Si_Chris
Correct.
The TPMS sensors are held in using a nut from the front side of the wheel. Use a deep socket to loosen, and pull the sensor out from the inside barrel (tire has to be broken from the bead around the area where the sensor sits, or tire removed completely).
If anything, you'll just need a TPMS rebuild kit, which are rubber, and metal washers, valve cores, and new nuts to hold the sensors on. These are typically less than $5 a wheel.
If you're planning on selling your stock wheels and tires, pull the sensors, and use them on your new wheels, no need to program anything, just swap the sensors over.
Old 02-19-2018, 06:55 PM   #10
Marty Bonesaw
Drives: 17 BRZ W/ PP
I’ve never had any issue with Toyota or Subaru with these TPms sensors Set of Two (2) VDO SE10001HP REDI-Sensor 314.9 MHz/315 MHz TPMS Sensor (PACK OF 2 SENSOR) https://www.amazon.com/dp/B01E4I089G..._mo2IAbF0CQBHX
We use them at work all the time, I have 4 ordered and should be here any day, once they come in I can let you know if they worked
Marty Bonesaw is offline   Reply With Quote
Old 02-23-2018, 05:52 PM   #11
hichamaziz
Drives: subaru brz
thank you Si_Chris
for website
hichamaziz is offline   Reply With Quote
Old 02-23-2018, 06:08 PM   #12
thatfilipinoguy
thatfilipinoguy's Avatar
Drives: 87 Supra, 13 FRS, 05 FXT
I have a set from wrx wheels I bought from someone a year ago. LMK if you're interested.
thatfilipinoguy is offline   Reply With Quote
Old 02-23-2018, 06:31 PM   #13
JMon85
JMon85's Avatar
Drives: 2019 WRX
I got mine from Toyota =P
JMon85 is offline   Reply With Quote
Old 01-30-2019, 02:56 PM   #14
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
Originally Posted by Marty Bonesaw
Marty Bonesaw I’ve never had any issue with Toyota or Subaru with these TPms sensors Set of Two (2) VDO SE10001HP REDI-Sensor 314.9 MHz/315 MHz TPMS Sensor (PACK OF 2 SENSOR) https://www.amazon.com/dp/B01E4I089G..._mo2IAbF0CQBHX
Any updates if these worked?
Clueless
YamahaR86 is offline   Reply With Quote
brz, subaru, tpms
FS: Set of TPMS sensors. GT86Dan Wheels and Tires 12 12-04-2016 08:24 PM
TPMS Sensors - What to Buy? Stang70Fastback Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 01-31-2016 01:01 PM
OEM TPMS Sensors airwak Wheels and Tires 3 08-16-2015 04:14 PM
Changed to new wheels w/o TPMS, car still thinks I have TPMS sensors? Ahz Issues | Warranty | Recalls / TSB 9 11-06-2012 08:25 AM
