Old 02-15-2018, 12:53 PM   #1
SquareMan
Removing Stickers From Tinted Windows
So I'm looking to remove a couple (imo) less than tasteful stickers on my windows that the previous owner placed. There's one on the glass over the B pillar on the driver's side and one in the lower left corner of the rear windshield. Additionally, the windows are tinted. I want to make sure that I don't damage the window tint with any products or tools that I use, as well as make sure I don't damage the rear defroster lines. Does anybody have any tips?
SquareMan is offline   Reply With Quote
Old 02-15-2018, 12:59 PM   #2
yelsew
Little Member
yelsew's Avatar
Drives: Bloo - The 13' BRZ
I am assuming the stickers are on the outside of the glass? Tint and defroster lines would be on the interior side of the glass so nothing should interfere. I would start with a clean razor blade and some glass cleaner, and maybe some solvent if there is too much residue.
<--- My Journal
People just need some #drivermod in their life.
yelsew is offline   Reply With Quote
The Following User Says Thank You to yelsew For This Useful Post:
Mr.ac (02-17-2018)
Old 02-15-2018, 01:05 PM   #3
SquareMan
Hmm, that's a good point. I'm not sure if the tint is on the inside or outside so I'll have to check to make sure but the stickers are on the outside.
Old 02-15-2018, 01:09 PM   #4
If on the inside it will be tricky. Use some Goo Gone in very small doses. Get an edge pealed up and put a small bit on. Peal a bit more and repeat. Make sure you wipe up each application as soon as the stick is lifted. Try very hard to not get any of the Goo Gone under the edge of the tint and do not pull un the sticker enough to lift the tint. When done clean the whole area with a glass cleaner that does not have ammonia in it.
I have had to do this before and after a couple of trial and error attempts was very successful using this method. It is slow though.
humfrz (02-16-2018)
Old 02-15-2018, 01:10 PM   #5
Vital
Drives: 2015 BRZ
Window tint is generally applied on the inside of the window. As far as removing the stickers, just get some 3M Adhesive Remover and you'll be good to go.
Vital is offline   Reply With Quote
Old 02-15-2018, 01:35 PM   #6
SquareMan
Alright thanks for the help guys. I'm going to attempt this this weekend and as long as the tint is properly applied i should have no issues.
Old 02-15-2018, 02:05 PM   #7
OH! I forgot to mention something! Use a hairdryer on low to heat them up a bit.
Old 02-17-2018, 12:09 PM   #8
SquareMan
Will heat not risk damaging the tint inside?
Old 02-17-2018, 12:15 PM   #9
No. Keep it on low and keep it moving. Think about how hot the inside of the car gets when parked on sunny and hot summer day. The tint isn't damaged by that. A blow dryer doesn't get that hot but it is enough to soften adhesive on a sticker. The heat is a far lesser risk than pulling to hard on the tint film.
Old 02-23-2018, 08:34 PM   #10
OfficeWorker
Drives: 2018 WRX STI
What material(s) are the stickers made from?
When removing stickers from the inside of the car where an aftermarket tint was applied, I've used a combination of a plastic razor blade with rounded points and diluted (regular) Dawn solution combined with quite a lot of time taking it very slow, and first testing the solution/effect of the razor blade on a portion of the tinted window that is not highly visible, and then shining an extremely bright light on the area to make sure the razor blade is not scratching the tint. During colder periods, I have used a hairdryer on lower settings without ill effects - although on extremely hot days this arguably is not necessary. After doing this, I've always tried to be very particular about removing any residue given how prolonged contact with a wide range of chemicals seems to has the potential to discolor tints. Depending on the sticker, getting the sticker itself saturated with the solution seems to sometimes help.
The specific tint itself seems to play a significant role in how robust it is against scratching/discoloration/tearing.
OfficeWorker is offline   Reply With Quote
What'd it cost to get your windows tinted? Series.Ru NY / NJ / CT / PA 21 08-26-2014 10:55 PM
Scion fr-s Tinted windows Scionshaun Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 5 05-14-2013 11:28 AM
Got my windows tinted! BryanGT Northwest 2 03-07-2013 04:51 PM
Finally tinted my windows and.... TheChopShop Cosmetic Modification (Interior/Exterior/Lighting) 5 08-21-2012 11:54 PM
Tinted Windows koolhawk CANADA 20 06-19-2012 07:27 PM
