Old 02-12-2018, 06:20 PM   #1
ShadowReaper
Indulgent Tormenter
ShadowReaper's Avatar
Drives: 15' LTD Subaru BRZ DGM
Clutch Install/Transmission/Shifting
I installed a Stage 2 Daily South Bend clutch yesterday.
I also put in:
-2.2 L of Motul 75w 90.
-New OEM flywheel
-pivot
-fork
Ever since I first test drove it till now, I have been finding it twice as hard to shift to first gear and ONLY first gear. I can even get Reverse easier. Also, my shift knob goes left (when on neutral) HALF of the distance it goes right (on neutral).
I have gaven it some thought. The only things I can think of is the washer under the shift boot is in the way, or was never there to begin with (I dont remember and my pictures didn't cover that portion). I did completely fuck up the rubber boot, and used electrical tape to seal it again, but I don't really think it's that. Could it be the white plastic on the shift?
If youve done a clutch install please chip in or if you're a mechanic wizard as well.
Instagram: Gabe.it.the.ole.college.try
ShadowReaper is offline   Reply With Quote
Old 02-12-2018, 07:19 PM   #2
toyubie
Drives: none
You might need to adjust the reverse lockout plate. Gap should be just a **** hair with the shifter in 2nd gear. Make sure it's square too.
See also this diagram to verify the linkage assemblies for the shifter:
toyubie is offline   Reply With Quote
Old 02-13-2018, 01:48 AM   #3
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Sounds like you missed something when reinstalling the shifter. Time to go back in and find out what you missed.
When I did my throw out bearing I did everyone from bottom. Taking off the center console was just too much of a hassle.
The Following User Says Thank You to Mr.ac For This Useful Post:
ShadowReaper (02-13-2018)
Old 02-13-2018, 08:52 AM   #4
ShadowReaper
Indulgent Tormenter
Ok. By the looks of this diagram it, I did have the cotter pin installed facing the opposite way, since it's a pain to get it to face the right way. It shouldn't be the washer according to the diagram and I don't remember seeing bushings any time.
Will need to take off boot and see what it's catching on. It's not an emergency, at least I can get it to first, just kinda ruins the whole point of getting good transmission fluid. Thanks.
Old 02-13-2018, 01:12 PM   #5
ermax
ermax's Avatar
The part in that diagram that is labeled "Shift Lever Cap" has some adjustability to it. It's the part of the reverse lockout. If that thing isn't right it will also sort of lock out 1st/2nd. I had to fiddle with mine when I did my TOB. I verified it was right before putting everything back together.
I took my center console apart because I couldn't get that stupid rubber boot off from the bottom and thought that I could release it from above. What a waste of time that was. Like @Mr.ac said, no need to remove anything from the top.
Next time I am in there to do a clutch, flywheel or TOB the job will be dramatically shorter thats for sure.
The Following User Says Thank You to ermax For This Useful Post:
Old 02-13-2018, 04:41 PM   #6
ShadowReaper
Indulgent Tormenter
Thanks for your input. That would make perfect sense if it was the shift lever cap, sine whatever its catching on seems like sturdy metal. I will take a look, tomorrow or thursday.
Old 02-13-2018, 05:04 PM   #7
ermax
ermax's Avatar
At least you don't have to tare it down too far to get to it. Still a pain though. I got lucky and noticed mine was all messed up before putting everything back together.
Old 02-15-2018, 07:35 PM   #8
ShadowReaper
Indulgent Tormenter
Brother you hit it right on the head.
I took a look today and playing around with the stick while I had everything taken off till under the foam and it was exactly that piece. Moved it slightly to the left.
thanks again
Old 02-15-2018, 08:17 PM   #9
ermax
ermax's Avatar
thanks again
Glad it worked out and wasn’t something bigger.
ShadowReaper (02-15-2018)
6th-5th grind due to transmission or noob shifting technique? tracerit Engine, Exhaust, Transmission 17 03-15-2025 07:44 PM
Transmission shifting when cold? jpilone Engine, Exhaust, Transmission 112 02-22-2018 03:48 AM
AT Transmission Hard Shifting MechEGR Issues | Warranty | Recalls / TSB 95 05-21-2017 11:54 AM
AT transmission hard shifting issues calic Issues | Warranty | Recalls / TSB 44 11-09-2015 06:17 PM
Transmission noise when up shifting after hard rev 1Cor10:23 Engine, Exhaust, Transmission 2 09-03-2013 03:22 PM
