Old 02-12-2018, 05:32 PM   #1
Bkdshadow
Drives: 2013 Scion FRS
Another OFT review
Hey guys, I know there are numerous threads on the Open Flash Tablet, but just thought I’d add on to it with my own review
The setup
So flashing the car from stock to what I’m at now (stage 1) was very simple for me. I literally took it out of the packaging, plugged it into the OBDII port, and everything was fine. I will say that I had to plug it in and out again about 2 times just because nothing loaded up initially, but it ended up working out, no big deal. Once the device was up and running, it was very simple to get to stage 1. Just pick your vehicle, let it read your ECU, then finally flash to the tune. The flashing process consisted of following the tablets directions of turning the car on (accessories, not engine), turning it off, confirming, etc.
TL;DR: VERRRRY simple and easy to install/flash from my experience.
The car
So after flashing, I was told to let the car idle for a little bit by the tablet. Before doing that I read on the forums about dead travel in the accelerator and saw that pressing the pedal several times with the accessories on would help. I pressed it in 20 times, turned the car on, let it idle(the idle is a lot smoother),then tested out the travel of it. I could notice the dead travel people were talking about still, and it was still apparent all of today while driving (this apparently goes away though).
Before setting off to test the power, I just had to make sure that it was there.... LAUNCH CONTROL! definitely want to lower it to 3500-4000 RPM, but awesome to know that my car has it now, very cool so after gushing about that I finally got on the road. Like mentioned before, the dead travel was prominent. I felt like I was gonna stall out the first time, but I got used to it fairly quickly. I honestly didn’t notice too much of a difference my first 15ish minutes of driving. On my second ride however (I went to the store for my first ride) I could definitely start to notice. I DD my car so I am constantly in that 2500-4500 RPM area. There is definitely more pick up there and it feels awesome. As a lot of other reviews on here state, this car feels how it should from the factory, I really feel like that’s the best description for what this tune does for the car. Shifting is also smoother, I’m not sure if this is a placebo effect or not, but I do think this is a benefit from the tune. I also feel a lot more confident on the high way as well with the passing power. The torque is definitely the most apparent thing with this car. I do feel the power up top as well, it pulls a good bit better IMO.
Final thoughts
I do think this is worth the money, and I think the benefits are very apparent on the first day. It allows you to monitor and datalog all of those ECU things if you want, it opens up the possibility of running a header (well, running it without a CEL), the engine idles more calmly, and the drivability is Improved a lot in my opinion. Stage 1 will not make your car fast, so I wouldn’t get this if you just want the HP gains. As others have stated, you will not get a punch in the stomach feeling by staying NA with this car. Speed and a car getting faster is relative of course, but I still wouldn’t consider the car fast. The car is definitely fastER and peppier, with the torque being the biggest benefit I think.
Very happy with the purchase and highly recommend
Side note: the knock correction was on 0 the whole time I was driving, but at one point the tablet started blinking even though it was on 0... not sure if this is normal?
Bkdshadow is offline   Reply With Quote
Old 02-12-2018, 06:48 PM   #2
Hadalet
Hadalet's Avatar
Drives: Argento FR-S
The setup
The car
Final thoughts
Nice. Now go get UEL headers, e-85, and rethink NA not being fast
Sent from my SAMSUNG-SM-G891A using Tapatalk
Hadalet is offline   Reply With Quote
Old 02-12-2018, 07:14 PM   #3
Bkdshadow
Haha I’m definitely downplaying the speed of the car. Don’t get me wrong it’s very quick I think I had a 2012 is350 and thought that thing was fast
Definitely going to invest in the headers though, then get the 4.56 gear setup! This car rocks
Old 02-12-2018, 07:41 PM   #4
Hadalet
Hadalet's Avatar
The diff is high on my list too!
Btw Is350 is a lot faster than our cars. It doesn't feel like it because it's so heavy, and it's power delivery very smooth
Old 02-12-2018, 08:41 PM   #5
Bkdshadow
Haha I know that’s the reason I speaking relatively with my post . They’re such sleepers, and their 1st and 2nd gears are brutal! People run them in the 1/4 mile in 13.6-13.7 consistently STOCK
Old 02-12-2018, 08:43 PM   #6
Hadalet
Hadalet's Avatar
Old 02-12-2018, 08:53 PM   #7
Lantanafrs2
Drives: 2013 frs red
I've found that part throttle operation improves substantially over the first 50 miles or so after reflash.
Old 02-12-2018, 09:49 PM   #8
Bkdshadow
Yeah that’s what I’m hoping for. I personally don’t mind it right now and it has gotten better. But as of right now stock was definitely better, and I could see why someone would be concerned
Old 02-13-2018, 09:36 AM   #9
tennisfreak
Drives: 2018 BMW M240i
Even with headers OFT is only getting you like 5hp and lessening of the torque dip.
For over $1k not really worth it IMO.
Old 02-13-2018, 10:22 AM   #10
Bkdshadow
A lot of what I read said the OFT helped bring out the potential of the headers,but yeah it’s only about 20ish whp at the end of the day for over 1k. I’ll take what I can get on this car I suppose. If I’m being honest though I really just want that Subi rumble just don’t want the CEL lol
Old 02-13-2018, 11:17 AM   #11
Lantanafrs2
5 horsepower my ass.
Old 02-13-2018, 11:51 AM   #12
Impureclient
Drives: 2015 FR-S
I like that you're thinking outside the box here but if you put it on your ass, it won't help the car.
Impureclient is offline   Reply With Quote
Old 02-13-2018, 01:00 PM   #13
Submarinesonce
Drives: Frs
170ish whp to 190-200 whp depending on fuel is only 5whp gain now?
JDL UEL Turbo GT2860RS, AP Racing BBK, Verus Splitter/diffuser/canards, Sard rep carbon wing, TFF bash bar, HKS hi power, Tein Flex A, Hotchkiss FSB, Radium MCB, Konig Hypergram 17x8, FS Indy 500, 6k HID, Whiteline trans bushing insert, Verus AOS, grimmspeed strut brace, Racerx oil cooler w/ setrab 619, ES steering rack bushings, Whiteline subframe bushings, Toms tails, STi mirror caps, IRP shifter, TRD Steering wheel
Submarinesonce is offline   Reply With Quote
Old 02-13-2018, 01:42 PM   #14
Hadalet
Hadalet's Avatar
I have full exhaust, oft, e-85 and I'm making 201 to the wheels...
Review || Blitz SUS Power Core intake kit, install/review mav1178 Engine, Exhaust, Transmission 4 07-05-2016 03:16 PM
Meguiar's Hyper-Wash Review - SON1C Synopsis Detailing Review SON1C Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 0 05-21-2016 06:56 PM
Product review separate from vendor review? Wonderbar Site Announcements / Questions / Issues 16 05-29-2014 05:18 PM
Perrin Pulley review? Invidia Q300 exhaust review? ScionFrsFan Engine, Exhaust, Transmission 4 12-10-2012 08:27 PM
AutoExpress BRZ Review - Follow up to the GT86 Review Zgrinch BRZ First-Gen (2012+) — General Topics 3 12-13-2011 08:03 AM
