Drives: 2014 BRZ Limited A/T
Before i buy my fluids - quick check?
Hi Guys, going to be changing fluids soon and buying the oils to bring to my local shop, car is stock with OFT Stg1, For DD and canyon only, rare track days. Tropical weather, never below 23 C here. 32 C average day temps.
Am i correct in what i am buying? Engine: 6 bottles of MOTUL H-Tech 100 Plus 0W20 = 6L Should i be getting the 300V High RPM 0W20 instead? I really want eneos sustina but they are hard to come by here. Differential: 2 Bottles of MOTUL Gear 300 LS 75W90 = 3L (1.3L per use. good for 2 uses) Read about the LS vs non-LS differential debate.. i dont know really.. just getting LS since theres nothing "bad" about it right? Automatic Trans: MOTUL Multi ATF = 8 bottles of this stuff? (7.5 liters needed) there's " Multi CVTF" "L ATF VI" "ATF-1A", and the most expensive one, "MULTI ATF". im just assuming MULTI ATF is the "best"? Last edited by leevanf; 02-12-2018 at 09:57 AM. |
#2 | |
humfrz |
| Keep Your Fluids in Check this Fall with FR Sport! | FRSport.com | Miscellaneous | 0 | 09-22-2014 12:46 PM |
| Motul fluids | Filipino Royale | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 88 | 04-20-2014 09:36 PM |
| How often are you changing fluids? | smbstyle | Tracking / Autocross / HPDE / Drifting | 2 | 06-07-2013 10:56 AM |
| When to replace the following fluids in the BRZ? | chenshuo | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 12 | 05-12-2013 12:17 PM |
| Stay away from quick check gas | DarkCard | NY / NJ / CT / PA | 1 | 12-17-2012 10:32 PM |
