Old 02-10-2018, 05:50 PM   #1
86TOYO2k17
Drives: 2017 toyota 86
High pitch loud noise after header and bpb install
I have a 2017 Toyota 86, about 3k miles. I just had ace header 250, and BPB installed. On the drive home every time I’m around 3k rpm there is a kind of loud high pitch noise.
I did flash to oft OTS Stage 2+ map right away so may try flashing to stock or stage one. Also they couldn’t remove the second 02 sensor so they put a metal 02 plug in. I am wondering if maybe that has to do with the noise. Took a few datalogs and may record a video later.
But maybe someone has some ideas? I popped the hood and nothing seemed loose or touching anything really. The cabin noise tube has some wiggle though not sure if that is normal was thinking about removing that anyways.
Old 02-10-2018, 07:52 PM   #2
humfrz
I'd suggest you take your car back to whoever installed the header and ask them to check for exhaust leaks.
humfrz
Old 02-10-2018, 08:09 PM   #3
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Header hitting something, or exhaust leak maybe.
Old 02-11-2018, 11:27 AM   #4
Sure you are not just hearing the normal sounds a header can create? The thinner walls and change in flow can create all sorts of weird sounds. Nothing wrong with them and it is the just nature of a header.
Old 02-11-2018, 04:42 PM   #5
idkwhatimdoing
idkwhatimdoing's Avatar
Drives: 2015 Scion FR-S 1968 Camaro BB402
Check the intake spacer first, then try looking at the exhaust. Sounds like an air leak... make sure there are gaskets under and over the intake spacer.
Hope this helps!
idkwhatimdoing is offline   Reply With Quote
Old 02-12-2018, 11:10 PM   #6
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
This sounds more like a vacuum leak issue due to the power blocks. You'll have to narrow it down by checking the header for leaks first.
Old 02-13-2018, 06:13 PM   #7
86TOYO2k17
Taking car back to the sho tomorrow to check it out and get a downstream 02 put in. I’m thinking it’s an exhaust leak, maybe between header and OP. Or maybe a hose came out or didn’t get clamped properly. Hope it isn’t a gasket or BPB issue.
Old 02-14-2018, 07:05 PM   #8
86TOYO2k17
Went back to shop, he checked/retightened everything, Nothing was loose or out of ordinary. Didn’t smoke test for vacuum leaks but AFR was normal. Nothing looked off visually. I revved car in neautal and no noise. But when driving the noise is at exactly 2.4k rpm. Sounds pretty normal before and after. He thought maybe a gasket wasn’t cut right and had a small lip inside. Although not hearing anything in neautral is odd.
Old 02-19-2018, 03:00 AM   #9
86TOYO2k17
Quick update. I used the cigarette lighter plug to plug the noise generator and I no longer hear the noise. Hoping this resolved the issue and it’s not something potentially dangerous to the car. Is it possible after BPB install that at exactly 2400rpm and only underload “in gear” that the noise generator could make a whistle like sound?
Old 02-19-2018, 03:15 AM   #10
humfrz
Thanks for the update.
That's why they call it a "noise generator" ........
Glad you got it figured out ...... just in time for ......"our winter" ...... brrrrrrr
humfrz
Old 02-19-2018, 07:42 AM   #11
jasonojordan
Drives: 2013 satin white brz limited
Id still check and make sure you don't have a vac leak that the noise generator was just amplifying.
jasonojordan is offline   Reply With Quote
Old 08-19-2020, 01:43 AM   #12
86TOYO2k17
Super old update necro. Resolved this issue 2+ yrs ago just forgot about this thread, figured I’d update for others. Header was rubbing the underpanel and at exactly that RPM the frequency made the weird noise similar to an exhaust leak sound. At the time I checked clearance and it had almost 1” of space but under load the engine rocks and takes up that inch. After a month or so header and skid plate had marks indicating where it was rubbing. Hammered underpanel down and noise/issue 100% gone simple fix.
bpb, header, high pitched sound, noise
High pitch noise in 6th gear D-rek07 Issues | Warranty | Recalls / TSB 27 11-02-2019 11:38 PM
loud clicking/knocking noise after turbo install drz400dude Forced Induction 31 06-16-2017 07:52 PM
Engine noise after header install? JW843 Engine, Exhaust, Transmission 8 01-29-2016 12:29 AM
Extreme High Pitch Noise Daned86 Issues | Warranty | Recalls / TSB 4 02-05-2014 11:44 AM
Fuel Pump high pitch chirp noise lucius AFRICA 9 10-24-2013 02:40 PM
