Motul 300V Mileage
Hello,
I kept hearing the Motul 300V is not meant for long duration btw EO change. Just couldnt find the recommended mileage online. For regular city driving (+ infrequent spirited driving), what is a reasonable mileage ... 6200mile/10000km ? I'm using 5w-30 (Dealer only have Motul or Shell Helix 5w-30) Thanks |
Drives: 2015 Scion FRS - Raven
I have used 300V and track my car quite a bit. I don’t use my car as a DD, so when it’s running it’s running at high rpm (I have a 5.29 rear gear). I change my oil every 2500 Miles (4000Km). I change the transmission fluid, brake fluid and rad water every year, I change the LSD oil every other oil change.
Drives: '13 BRZ Limited
Blackstone told me I should go 7,000 miles between changes based on how my 300v looked after 5,000 miles.
This is including Boost, E85, and Monthly track usage. Oil cooler too of course. Motul 300V 0w-20 Last edited by Kordless; 03-01-2018 at 10:20 AM. Reason: EDIT: 7,000 miles, not 8,000. |
#4 | |
Drives: 2018 WRX STI
![]() I've read on BITOG that 300V has a pretty solid additive package, making it capable of very reasonable drain intervals while simultaneously being able to hold up to engines/usage that can be harder on oil. |
Drives: Subaru BRZ
Any major difference between 300v 0w20, 5w20 &5w30?
#6 | |
Still good though. I'll try 7,000 and I'll send it back to them with more 300v ![]() Love this oil so far.
Whats up with the makeup oil added?
Drives: 2014 Whiteout FRS
I have only ever ran Motul 300v 5w30 in my car, aside from what came in it from the factory. I have done many track days, some with 120 degree ambient temperature.
I have gone 10,000 miles consistently on e85. I had Blackstone run a few reports and they were saying I could even push 12,000 miles. Now that I am boosted I change it around ~5000k miles just for peace of mind. Do I recommend doing this? Probably not, but I got lazy and tired of spending $120 every 2 months to change the oil. |
#10 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
How much of the 10k miles was street vs track? |
#11 |
I would guess around ~350 miles of track time per change. Usually 4 track days per oil change so whatever that equates too.
Everything else is street miles, primarily highway. |
#12 |
Used oil analysis is your friend
#13 |
I plan to, I just want to see if 5k+ has been seen by others. Also want to get an idea of when the first change should be to send it in and know if there was hope of not having to change my oil every 2 months lol |
#14 | |
| Motul 8100 Eco Lite vs Motul 300V vs Eneos Sustina | Lust | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 58 | 08-28-2017 07:10 PM |
| 6L of Motul 0W20 300v + 2 Filters | rever5e | Engine, Exhaust, Bolt-Ons | 2 | 06-19-2015 04:22 PM |
| Motul 300V 10W40 Synthetic Oil 6L | sw20kosh | Mechanical Maintenance and Tools | 0 | 06-12-2015 04:53 PM |
| motul 300v | 86Tony | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 2 | 06-04-2015 11:04 AM |
