Old 01-28-2018, 01:26 PM   #1
krat0$
Drives: 2017 BRZ
OFT on stock
Good day, guys! Sorry, just a newbie on this one. I was wondering if this is going to be a worth buy or if there’s any or even a little noticeable gain being used on a stock 17 brz, just with a catback exhaust. TIA!
krat0$ is offline   Reply With Quote
Old 01-28-2018, 03:30 PM   #2
JermMX5
Drives: 2017 Toyota 86
I dynoed my 2017 before and after stage 1 complete stock: http://www.ft86club.com/forums/showthread.php?p=2963580
Not worth unless you plan to get headers eventually except for maybe the redline if you do autocross
2017 Toyota 86 - Whiteline 20mm Front Bar | Crash Bolts | 235/45/17 RE-71R | 17x7.5 OZ Omnia | OFT Stage 1 For Street Driving | Trackpipe for AutoX | Not enough camber.
JermMX5 is offline   Reply With Quote
Old 01-28-2018, 05:46 PM   #3
PuslarBrrrz
Its worth it if you want to run E85 otherwise wait for headers like said above.
PuslarBrrrz is offline   Reply With Quote
Old 01-28-2018, 06:01 PM   #4
krat0$
Drives: 2017 BRZ
Thanks guys! Probably will save first to get new headers
Old 01-28-2018, 09:39 PM   #5
Lincoln Logs
Lincoln Logs's Avatar
Drives: #337 2017 Toyota 86
My experience with the Stage 1 tune, 3.02, was good on my stock 2017 86. Throttle response is better and it doesn't hang between shifts like the stock tune does occasionally. Does it change it into a rocket ship? No but I think there are more benefits than the numbers on the dyno suggest.
I think the best part of OFT is the ability to run E85 on an otherwise stock car - best bang for buck when it comes to a horsepower increase.
Lincoln Logs is offline   Reply With Quote
Old 01-28-2018, 10:22 PM   #6
krat0$
Drives: 2017 BRZ
Yeah, this is also what I noticed. It hangs between shifts
Old 01-29-2018, 04:50 AM   #7
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
IMHO if you are going to upgrade to stage 2 later, get the OFT as soon as you see a deal on one used. Stage 1 doesn't give you much, but it''l give you a little and you'll have the tablet for when you upgrade. It's definitely worth it for stage 2- big gains.
If you are never going to upgrade to catless, don't bother with the OFT. Stage 2 is for catless. Stage 1 is for catted. Stage 1 alone isn't worth an OFT.
Old 01-29-2018, 08:48 AM   #8
krat0$
Drives: 2017 BRZ
Thanks!
Old 01-31-2018, 12:37 AM   #9
Carbinebbq
Carbinebbq's Avatar
Drives: 2017 BRZ Limited
I remember when I called Shiv regarding the 2017 tune he said stage 2 would be fine for catted header. I think this was version 2. Car runs smooth for me.
Sent from my SAMSUNG-SM-G930A using Tapatalk
Carbinebbq is offline   Reply With Quote
FS: Stock brake lines, stock clutch line, stock motor mounts Agent_D Brakes, Suspension, Chassis 4 08-22-2017 12:24 PM
WTB: Stock Intake, Stock Radiator, Black Front End Body Parts nmullin11 Want-To-Buy Requests 0 06-14-2016 09:23 AM
FS: Openflash, Weathertechs,Mtech Trasmission Springs, Stock Exhaust, Stock intake Brahsbrah Canada Classifieds 11 11-09-2014 11:03 AM
WTB: Stock MAP Sensor, Stock Frontpipe, Stock Midpipe. Sterz Engine, Exhaust, Bolt-Ons 4 07-02-2014 09:22 PM
