Old 01-26-2018, 11:12 AM   #1
Barefootdan
Barefootdan's Avatar
Drives: 2017 BRZ
P015A Code
Has anyone had issues with this code appearing before? I have done some searching for it and there is not much information on the code.
I have a 2017 manual with a Tomei UEL header and delicious tune for 91oct. I get this code every now and then. I won’t see it for a couple thousand miles, and then it’ll appear. Once or twice it cleared itself. This time I did notice that it came up right about 40-50 miles after filling up with gas from a QT instead of my normal Shell. Maybe this is coincidence? Any help would be appreciated.
I have checked the header twice for leaks. First was a visual check with soapy water. Second was me undoing all bolts and retorquing them. If this isn’t a fueling issue, I’ll take the header off completely tonight to inspect the gaskets and use copper gasket sealer as an extra step when installing.
Edit: here is a cruising log a few days before the code showed up. I can upload one tonight with the code if it doesn’t clear itself. https://datazap.me/u/barefootdan/log...7?log=0&data=6
Thanks!
Dan
Barefootdan is offline   Reply With Quote
Old 01-26-2018, 06:48 PM   #2
Kodename47
Kodename47's Avatar
Drives: UK GT86
A quick Google pulls up:
If the O2 sensor in question fails to cycle as rapidly and/or regularly as expected, over a set period of time and under certain predetermined circumstances, a P015A code will be stored and a malfunction indicator lamp may be illuminated.
Possibly a sign the O2 sensor is on it's way out?
.: Stealth 86 :.
Kodename 47 DJ:
Old 01-26-2018, 07:27 PM   #3
Barefootdan
Drives: 2017 BRZ
That sounds like a good culprit. Easy fix to test as well. Thanks
Old 01-29-2018, 09:32 AM   #4
Barefootdan
Drives: 2017 BRZ
Just an update for anyone who runs into this. I checked my header again for any leaks with some soapy water. None found. No soot or blackness around the header either. I filled up with shell 91 and about 75 miles later the light went off. Either my car hates QT gas or this is a huge coincidence!
Old 01-29-2018, 05:59 PM   #5
steve99
LTFT look a little high at low rpm and high positive as well. usually a sign of a small exhaust leak
info on code diagnosis
http://www.sucross.com/dtc_p015a_a_f...or_1-1834.html
Old 05-03-2018, 08:31 PM   #6
tfp
tfp's Avatar
Drives: 2017 BRZ WRB with PP
My 17 MY threw this also today while going 70. 1/4 tank of e85 left. Having a friend clear it for now.
Sent from my SAMSUNG-SM-N910A using Tapatalk
tfp is offline   Reply With Quote
Old 05-03-2018, 08:35 PM   #7
wbradley
Sarcastic SOB
wbradley's Avatar
Helped a guy on the weekend with that code in the track parking lot. Did a visual and his secondary O2 sensor was so loose you could spin it!
Another CEL code whitefrs Forced Induction 20 11-27-2019 11:27 AM
p0462 fuel level sensor code. anyone else ran into this code georgiafrsguy Engine, Exhaust, Transmission 1 02-28-2017 08:28 PM
Lean Code and 02 Code diagnostics. Kiske Engine, Exhaust, Transmission 12 04-28-2016 10:19 PM
Code C1201 Dipstik-sportech Issues | Warranty | Recalls / TSB 2 06-26-2014 10:12 PM
CEL code ChandlerSwyng Issues | Warranty | Recalls / TSB 2 04-08-2014 01:27 AM
