Old 01-22-2018, 10:30 PM   #1
xenarc
xenarc's Avatar
Drives: 2017 SUBARU BRZ
Disappointed at LaminX
I got my LaminX today for my 2017 Fog lights and I was disappointed at the precuts for this fog light style. Not only that but I expected a deeper yellow, Instead i got a light yellow output.
I should've purchased a whole sheet instead.
xenarc is offline   Reply With Quote
Old 01-23-2018, 08:59 AM   #2
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
I'm happy with mine.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 01-23-2018, 09:16 AM   #3
Vital
Drives: 2015 BRZ
same had mine for a year now and im happy with them no issues with discoloration either
Vital is offline   Reply With Quote
Old 01-23-2018, 09:21 AM   #4
bababooey
Drives: BRZ SWP Limited -6MT
satisfied with mine as well, 3+ years on all time headlights are on, no discoloration. and the solution to deep yellow output would be actual bulbs that emit yellow light.
OP i suspect you may need to order the 13.14.15 version.
Old 01-23-2018, 09:32 AM   #5
8RZ
The Gunshine State
8RZ's Avatar
If you want a brighter, deeper yellow then you should look into 3k HID bulbs.
Current DD: M235i
Old 01-23-2018, 09:49 AM   #6
xenarc
xenarc's Avatar
The 2017 fog lights do not use bulbs. They have built in LEDs.
Old 01-23-2018, 09:58 AM   #7
8RZ
The Gunshine State
8RZ's Avatar
Oh ok, nice. I wonder if anyone makes yellow LEDs for them yet.
Current DD: M235i
Old 01-23-2018, 10:40 AM   #8
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
LED's through Laminx/film often ends up with slightly wonky colors. My sister has a set of 5000k LED foglights that to the human eye show up as a nice pure white. I got her some yellow laminx and the two together show up as a weird pea green color.
Swapped in some 4300k halogens, and it's a nice yellow color, some 5000k halogens and it's a bright/light yellow. Back to the LED's and it's green.
In my 15, I got the blacked out glass depo housings for the outback, and added 3000k Hella halogens with an adapter harness. They look fantastic, but I don't know if the 17+ wiring can support the wattage, as they are made for LED's not halogens like the 13-16 cars are.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 01-25-2018, 05:54 PM   #9
KMA KiCKz
Certified Wumbologist
KMA KiCKz's Avatar
Drives: 2015 Scion FR-S
Sorry to hear that they gave you some weird cut outs. I had the lamin-x fog light covers on my frs. About a year, no complaints. A little over a year and a half, I started noticing a darker shade in the middle of the cover. A few months later, it had gotten bigger and found out it was burning it and it had hardened. Perhaps I had installed them incorrectly, but it definitely protected them from all the rock chips in the free way. I ended up scarping it off and just running it without it. I am running stock bulbs if that helps.
KMA KiCKz is offline   Reply With Quote
Old 01-25-2018, 06:01 PM   #10
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Huh, I have em on mine since '14 and don't have any issue on headlights nor foglights... but I am running LED foglight bulbs from Diode Dynamics, so output temperature might be different
Will yellow laminx affect light output?(got em) Pho20 Cosmetic Modification (Interior/Exterior/Lighting) 20 08-02-2017 07:42 PM
SOLD: LaminX Headlight,SideMarker, Fog Lights, Reverse Light zc06_kisstherain Exterior Parts (Aero, Lighting, Etc.) 55 10-11-2016 01:20 PM
I'm very disappointed with Toyota.. husker741 Scion FR-S / Toyota 86 GT86 General Forum 255 09-25-2013 01:34 AM
Is anyone else disappointed by the STI offerings so far? Superhatch BRZ First-Gen (2012+) — General Topics 16 10-18-2012 08:46 PM
I'm Disappointed Kage BRZ First-Gen (2012+) — General Topics 54 02-06-2012 02:51 PM
