Old 01-19-2018, 03:02 PM   #1
Bread1
Drives: Scion Frs
What are some good coilovers for an frs under 1000?
Bread1 is offline   Reply With Quote
Old 01-19-2018, 03:13 PM   #2
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Good for what?
A) Just being lower
B) Comfort DD
C) Track Use
D) All-Around
Hint: Option D - Doesn't really exist.
I LIKE TIRES!
Old 01-19-2018, 03:16 PM   #3
jasonojordan
Drives: 2013 satin white brz limited
Ive enjoyed the ISC coilovers I have on my BRZ
http://www.ft86speedfactory.com/isc-...l#.WmJR_KinGHs
jasonojordan is offline   Reply With Quote
Old 01-19-2018, 03:46 PM   #4
Bread1
Drives: Scion Frs
I'll check them out thanks!
Old 01-19-2018, 03:46 PM   #5
Bread1
Drives: Scion Frs
Good for what?
A) Just being lower
B) Comfort DD
C) Track Use
D) All-Around
Being lower and everyday use
Old 01-19-2018, 04:23 PM   #6
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I assume that you don't want springs and shocks; because you want 9.5" wide wheels.
I have 65,000 miles on prokit springs (same as TRD) and stock shocks. Cost me $235.
Something most guys do not talk about: Coilovers have a life of 50K or less. And then will need rebuilt. So, buying an inexpensive set is not always the best idea. Additionally, many of the less expensive coils are not rebuildable, have poor customer service, or if they are rebuildable you may have to pay to ship them out of the country.
I have read many reviews of coils under 1000. Most guys will give a glowing review of what ever they decide. And, since they are buying in the 1000 and under range, probably have not tested other coils. Making a side by side unbiased opinion hard to find.
Keep reading suspension threads in the tech section. Ask some specific questions. Then, make a decision.
Good Luck!
I LIKE TIRES!
Old 01-19-2018, 04:32 PM   #7
Bread1
Drives: Scion Frs
Good Luck!
Hmm didn't know that so you just lowered ur car with lowering springs and what wheel size do u have on it?
Old 01-19-2018, 04:37 PM   #8
Leonardo
Country Boy 4 Life
Leonardo's Avatar
18x8 +35 225/40 & 18x9 +37 245/35
Konig oversteer wheels. MPSS tires. W/ 10mm front and 5mm rear spacers. ( wheels are +45 and +42 before spacers )
I have camber bolts in the front.
I LIKE TIRES!
Old 01-19-2018, 05:01 PM   #9
TMF
TMF's Avatar
Drives: '14 FRS TT5
Good coilovers under $1k do not exist, unless you just want to slam your car.
Lowering springs and upgraded dampeners are:
1. Cheaper
2. Handle better (than stock or crappy coiliovers)
3. More comfortable for a DD (e.g. when Koni's are set to full soft, they have arguably a better ride than the stock dampeners)
I ran TRD springs and Koni's and I was still able to fit (with ease) 17x9 +35 wheels. Looked pretty decent in my opinion as well.
On an related note (sorry for the shameless plug), I will be selling these TRD springs (and front/rear sway bars) and Koni's (koni's will be on the car until Spring though). Price? Less than 1k lol. Hit me up if you're interested.
Follow my NASA TT5 build here: JHill Motorsports
TMF is offline   Reply With Quote
Old 01-19-2018, 05:07 PM   #10
Bread1
Drives: Scion Frs
Those look great on the car I might look into getting some black version for my firestorm frs! And they a cheaper
Old 01-21-2018, 10:19 AM   #11
bmacfrs
bmacfrs's Avatar
Drives: 2013 FRS
If you are willing to buy a used set that opens other possibilities also. You get better quality and spend less.
I just happen to have a set of RSR sports-i that I could sell. Less than 5k miles on them. Would be a good choice for what you describe.
Sent from my SM-G930V using Tapatalk
WIFE: "How can there be anything left to buy?"
bmacfrs is offline   Reply With Quote
Old 01-21-2018, 11:23 AM   #12
Teseo
Drives: frs
Tein Flex z
Old 01-21-2018, 12:45 PM   #13
jamal
jamal's Avatar
Drives: Legacy GT
To answer the question, I would check out the ST coilover (they're like a kw v1), and some of Tein's new stuff like the flex z. Bilstein B14 is also in the neighborhood but a little more expensive.
jamal is offline   Reply With Quote
Old 01-21-2018, 06:41 PM   #14
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
https://frsport.com/Sports-Suspensio...p_1554783.html
Trueweltall is offline   Reply With Quote
HSD Monopro Coilovers $1000 - Used for Less than 400KM mdmike73 Brakes, Suspension, Chassis 0 09-21-2017 09:25 AM
Good coilovers under $1,000??? Sabretooth Suspension | Chassis | Brakes -- Sponsored by 949 Racing 64 01-08-2015 06:18 PM
has anyone a good full bodykit for about 1000? riironman Cosmetic Modification (Interior/Exterior/Lighting) 7 11-15-2013 07:04 PM
megan ez street coilovers good or bad? juanam0909 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 10-02-2013 04:34 PM
Hi guys anyone know a good local shop to get tein coilovers ?? s1monn Southern California 3 01-28-2013 05:30 PM
