Drives: 2015 Subaru BRZ Series.blue
Sorry But - Updated OFT Vs Ecutek?
Sorry to post something that has been done multiple times. The most I can find are years old, though.
I have the OFT, and was considering moving over to ECUtek due to the tuner availability. I like the OFT a lot, but the ECUtek phone app and other items do look a bit easier and quite useful (launch control via phone in real time?!). My question is: How much of a difference is there as far as ability goes between the two? I have seen so many posts or comments about OFT can't do this or that only to have Shiv come in and correct them. Are there things that Ecutek can do that OFT cannot? If I am boosting does it really matter which? Some say ECUtek if boosted, but I know OFT can handle boosted applications too. Is this preference and options only, or is there a reason to go ECUtek over OFT other than the sweet phone app and triple maps? Again, sorry to ask the question I am sure has been asked a million times, but I don't see any newer posts with updated info, and I assume things have been added/changed for both platforms.
Please only adult answers.
I'm stupid, retarded, a fkn idiot, and I will kill myself after a couple answers, I already know this (thanks to the interwebs and its logic) so feel free to leave those responses out, thanks. |
Start with link below
http://http://www.ft86club.com/forum...d.php?t=106068 NA car only go ecutek if you want the festures. You can get same results with oft or tactrix. OFT has flex tunes for 2012-2016 No flex fuel for 2017 yet You dont need ecutek phone app to switch maps or adjust launch control you can alresdy do it via cruise stalk. You will get nore tuners options with ecutek Hence you will get more fi kits supported than with oft For higher boost appications and electronic boost control and multiple failsafes it starts to swing toward Ecutek If you were just going for say basic SBD kit at 10psi then oft will be fine. If you wanted to run higher boost with electronic boost control and switchable boost maps then you would need ecutek. If you want to look at the tunes and see changes as you get custom tune and maybe tweak the odd thing yourself then mabe oft. Although james as HRI tuning doesnt lock his ecutek tunes, but you would need racerom extension ro resrly see what going on as standard ecutek softwsre you cannot see or edit custom maps even in unlocked tunes Jist depends what you want |
#3 | ||
Drives: Toyota GT86
Steve's link corrected:
http://www.ft86club.com/forums/showthread.php?t=106068 Quote:
http://www.ft86club.com/forums/showp...46&postcount=5 Quote:
3 questions: - What hardware changes do you have? - Which tune are you running now? - What is your goal? Yes, there is a lack of tunes who publicly offer to tune remotely using OFT. In fact, I can only think of Shiv. I posted this... http://www.ft86club.com/forums/showp...&postcount=477 ...in the Gruppe-S header thread. If you are interested I would offer this even if your car doesn't have a Gruppe-S header.
Drives: 2017 BRZ
It's nearly 3x the cost to get the Bluetooth and everything else from Ecutek (unless I was misinformed about needing the standard cable still).
That said, I think it comes down to whether you're after a setup supported by OFT already or not (that could include any of the many shared maps, etc.)
@Tor I am mid turbo install (ups managed to steal or lose the turbo from the kit so I'm going on 2 months since I ordered).
I have a bunch of stuff done. Gruppe-s uel headers (had em a while, love em) Full exhaust (single exit) Pulley kit I did get an electronic boost controller (sitting in the pod waiting for the turbo) 18x9.5 wheels Oil catch can (mishimoto) Other stuff that doesn't matter for turbo. Had to remove my intake and dp for the turbo kit. I've had oft for years, but I think it's time for the switch. I'll be doing remote first and later in the year, dyno (none close that I know of is why). I'd like to tune or tinker myself but not just yet so that portion of ecutec can wait. Sent from my SM-G950U using Tapatalk
Also thank you everyone for the replies to the worn out question.
I'll go over/through the suggested threads. Sent from my SM-G950U using Tapatalk
#7 | |
Car is on jack stands waiting for the turbo to be dropped in. Sent from my SM-G950U using Tapatalk
#8 | |
It sounds like you can do some tuning with the dongle, just not full fledged tuning. I think it requires an upgraded RaceRom before you can full on tinker, but it sounds like you can upgrade to this any time. Not gonna lie, their product page and videos are confusing together (For me). Not sure what I get with what products, or how many products there are. Time to read some more!
Drives: Toyota GT86
Tuning forced induction is more critical, so not the best to start tinkering with yourself. Like you said, it limits the available tuners if you are not going Ecutek. Combined with the advantages Steve mentioned above with Ecutek and forced induction and there is your answer?
#10 | |
Reading some books and watching Ed videos, not quite there yet heh. Sent from my SM-G950U using Tapatalk
#11 | |
you couuld use an external electronic boost controller like plex https://www.plex-tuning.com/product/...troller-basic/ but they cost heaps as above and its actually cheaper and simper to get ecutek tuneing system which can use standard ecu to control a cheap 3 port boost solenoid directly. If you want an open ecutek tune you can look at ie not locked use James Martin at HRI tuning. https://www.hrituning.com/ hes one of the few ecutek tuner that does not lock tunes |
#12 |
Drives: UK GT86
You can flash with the BT-EVI but not sure if you can get a dongle with one/separately. That would reduce costs, might be worth checking with some vendors.
.: Stealth 86 :.
#13 | |
. I have a 3map with the turbo kit. Idk how that works when the boost controller has the map controller on it. I assume the one on the engine isn't used? Sent from my SM-G950U using Tapatalk
#14 | |
Drives: 2017 BRZ
It's too bad, because it would make logging for tune tweaks (which is common when you get an off-the-shelf tune from the good vendors) rather simpler. I don't look forward to the hour+ drive so I can do a few good pulls...
| My updated WTB thread | Ignore Your Doctor | Want-To-Buy Requests | 3 | 11-27-2017 05:18 PM |
| OFT OTS tunes to be updated to V3! | guybo | Software Tuning | 20 | 01-31-2017 11:24 PM |
| FS: Various Parts *UPDATED 07-10-16* | JPxM0Dz | Canada Classifieds | 5 | 07-10-2016 02:56 PM |
| So when will we get updated about FT-86? | Dark | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 04-23-2010 02:05 PM |
