Old 01-10-2018, 07:52 PM   #1
TOLM
Drives: Brz
End of break in period
I have 1575 km on the clock which is almost 1000 miles. Would appreciate your thoughts on the following three:
1) Does this mean i can start driving this thing the way it is meant to be driven?
2) Would you recommend doing an oil change at this point in time? My next scheduled regular oil change is in 2 months (I walk to work.. only 1000 miles in 4 months since bought the car)
How about gear box oil and rear differential? I know sound crazy doing these at 1k miles but the logic says since this is a branf new car, the components are breaking in and lots of free metal particles are likely (I have 5 quarts of Genuine OEM Subaru 75W-90 Gear Oil - 4 Quarts (Bottles) (SOA427V1700) which should be sufficient).
3) I know i am not very smart but i often shift at pretty high RPM (like 5-6k) and drive my cars in a pretty spirited manner. (I actually bought the car as wanted something lil and sporty. I plan doing some occasional auto-x.) I am a bit worried about the 0w20 recommended oil. Can/shall I just switch to 5w30? I normally buy pennzoil platinum ultra.
Thank you all!!
TOLM is offline   Reply With Quote
Old 01-10-2018, 08:07 PM   #2
humfrz
Thank you all!!
Well, hello, TOLM and welcome to driving your broken in machine.
1. I wouldn't start slamming off the rev limiter all the time right away; maybe take er up to only about 6000 rpms for the next few thousand miles. The main thing to remember is to get the engine good and warm before you wind it up tight.
2. For average driving, I would suggest you follow the owners manual for the frequency of oil changes. Back-in-the-day, we used to change the oil after the first few hundreds of miles ..... to dump all the metal shavings out of the crankcase ....... not necessary these days.
As far as the gear box and differential ...... no need to change those fluids now ..... there ain't no combustion going on in there.
3. I reckon a good quality full synthetic 0w20 is just fine for this car under average driving conditions. Now, if your car lived near red line, on a track, in the desert,..... maybe a heavier oil might be beneficial.
There ya have it from the old, non racing, humfrz
humfrz is online now   Reply With Quote
The Following 5 Users Say Thank You to humfrz For This Useful Post:
Sarlacc (01-10-2018), Spuds (01-10-2018), STV3 (01-12-2018), Tcoat (01-10-2018), TOLM (01-10-2018)
Old 01-10-2018, 08:20 PM   #3
Borchert97
Borchert97's Avatar
Drives: 2017 Toyota 86
I did a harder break-in anyways so I'd say you're good to go wild by now.
Borchert97 is offline   Reply With Quote
The Following User Says Thank You to Borchert97 For This Useful Post:
TOLM (01-11-2018)
Old 01-10-2018, 08:41 PM   #4
All this ^. Nothing more. Nothing less.
/Thread
humfrz (01-10-2018), Sarlacc (01-10-2018), STV3 (01-12-2018), TOLM (01-11-2018)
Old 01-10-2018, 10:43 PM   #5
CB750F
CB750F's Avatar
Drives: 2015 BRZ WRB
1- Drive it... Once the engine warm, let her rip, red line a few times a day is good.
2 - Some do, some don't I waited, no ill effects. 50k km. We don't live in Texas with crazy heat, I would not worry.
3 - I changed my diff at 30k, it was dirty, maybe at 10k it would have been changed, but again, how anal do you want to be? Still did not do my trany oil & I bought it at same time as the diff oil.
4- Drive safe, only do shit at autoX & lapping, not worth it on public roads. Don't drink & drive, & don't smoke & drive.
CB750F is offline   Reply With Quote
The Following User Says Thank You to CB750F For This Useful Post:
TOLM (01-11-2018)
Old 01-11-2018, 02:00 PM   #6
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I mashed out of the dealership back in 2012 and never looked back. You're good to go!
OP, just make sure the "Broke-it" period does not follow the "break-in" period.
I LIKE TIRES!
The Following 3 Users Say Thank You to Leonardo For This Useful Post:
bcj (01-11-2018), NyC Zn6 (01-11-2018), TOLM (01-11-2018)
Old 01-11-2018, 03:37 PM   #7
strat61caster
strat61caster's Avatar
1. yes
2. no
2a. no
3. no
I followed break in, car appears to be in good kit after 66k miles, lots of autox, over 5x track days, regular factory suggested change intervals (7.5k on oil), mostly 0w-20, I tried 5w-30 and the oil reports noticed some reduced wear but I believe that's the engine still settling, we'll see if my next change of 0w-20 shows increased wear or maintains the trend, I may reverse my opinion and go back to the 5w-30 if I show increased wear on the 0w-20 in a few weeks.
However your cooler climate will benefit more from the 0w-20 than mine, the 5w-30 will be thicker in the cooler temps and may hurt oiling performance unless you spend more time at the track than idling along in commute traffic in the cold.
I did differential and transmission fluid at 30k and then again at 60k because of the hpde and autox usage, factory recommended is 60k iirc, unless you're driving more than "spiritedly" quite frequently I don't see much reason to shorten any intervals on the car nor change away from factory fluid specs.
If flushing the factory fluids out before the first specified interval had any value it would be in the procedure. Toyobaru doesn't want to sell a car that goes to shit in a short amount of time if that can be prevented with ~$100 of fluid maintenance in the first few months of service, that'd be chump change in comparison to the outrage and brand damage caused by accusations of poorly made cars.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
humfrz (01-12-2018), Leonardo (01-11-2018)
Old 01-11-2018, 05:10 PM   #8
bkharmony
bkharmony's Avatar
Drives: 2017 86GT
I changed the oil right after break-in. I knew it wasn't necessary, but for 75 bucks, why the hell not?
bkharmony is offline   Reply With Quote
Old 01-12-2018, 12:37 PM   #9
humfrz
Because of 75 bucks ...... ??
humfrz
The Following 6 Users Say Thank You to humfrz For This Useful Post:
Doubletap (01-12-2018), Leonardo (01-12-2018), pushrod (01-13-2018), strat61caster (01-13-2018), STV3 (01-12-2018), VoltsFRS2013 (01-13-2018)
Old 01-13-2018, 04:02 PM   #10
VoltsFRS2013
VoltsFRS2013's Avatar
Drives: 2022' GR86 Premium 6MT
humfrz
What kind of oil are we using here that it required $75.00 to have an oil change done? (assuming you did it yourself)
22' Toyota GR86 - Trueno Blue - M/T (CURRENT)
18' Toyota 86 GT Black - Moonslate Gray - M/T (SOLD)
13' Scion FRS - Ultramarine - A/T (SOLD)
VoltsFRS2013 is offline   Reply With Quote
Old 01-13-2018, 04:47 PM   #11
Brink
Drives: 2017 BRZ
Dealership threw in a free break-in oil change when I bought mine.
Brink is offline   Reply With Quote
Old 01-13-2018, 04:55 PM   #12
humfrz
What dealership did you buy your car from .......
humfrz
Old 01-13-2018, 05:02 PM   #13
Brink
Drives: 2017 BRZ
humfrz
Carlsen Subaru in Redwood City.
Old 01-13-2018, 05:02 PM   #14
humfrz
It must have been very old and very rare ......
humfrz
No Break-In period? hypebrz Issues | Warranty | Recalls / TSB 20 05-05-2016 03:46 PM
Break in Period Pegasus Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 34 03-23-2014 04:25 AM
Break in period KonTheory Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 10 02-05-2014 12:03 AM
Break in period almost over! Trmx2 Scion FR-S / Toyota 86 GT86 General Forum 32 11-15-2013 03:07 PM
Break-in period...what's really going on? CaptainSlow Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 23 04-27-2013 01:43 AM
