Old 01-07-2018, 12:51 AM   #1
Impureclient
Drives: 2015 FR-S
Auto Fitment Calculator been dead for a while now
So the Auto Fitment Calculator is down and has been for a while. Link to the calculator by itdansharpe: http://www.ft86club.com/forums/showthread.php?t=25177
You used to be able to use this: https://web.archive.org/web/20160302...roject.com:80/ and you could still use it but now it will let you put a couple fields in and redirect out of it.
So Dan has been gone for a while and appears to have lost interest in his nice little tool there. Is there anything close to this tool that will show you where our fender sits.
Is it possible to take that and make it active again or is that like an old unused car parked in somebody's yard that is still theirs that cannot being used by anybody?
Impureclient is offline   Reply With Quote
Old 01-07-2018, 01:04 AM   #2
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Www.Willtheyfit.com This really helps.
Tirerack.com has a great tire calculator.
I use these websites. If known limits are used, which can be found in the wheel directory and the meaty tire thread, you can figure out if something will rub the strut or fender.
I LIKE TIRES!
Old 01-07-2018, 01:43 PM   #3
df.dima
Drives: FR-S and Mazda 3 Sky
His personal site still looks up, maybe try getting a hold of him via his contact at dansharpe.com?
I looked at what wayback machine, not sure how they archive, but it looks incomplete, I do not see relevant javascript files in place (I'm assuming this calc is built with that), because it just has static html page, but nothing backing that up.
I remember using his calculator and I liked that it's more FRS specific, and it did show fender diagrams, but I remember it seemingly being a bit too conservative when I plugged in the "golden standard" 17x9+35 setup when I was trying to figure out how much camber would make it look "flush".
df.dima is offline   Reply With Quote
Old 01-13-2018, 07:03 PM   #4
DuMa
DuMa's Avatar
Drives: LR BRZ Limited
https://www.wheel-size.com/calc/
DuMa is offline   Reply With Quote
Old 01-13-2018, 09:54 PM   #5
Code Monkey
Drives: Subaru BRZ
I like this one.
Code Monkey is offline   Reply With Quote
Old 05-07-2018, 08:44 PM   #6
BurnetRhoades
BurnetRhoades's Avatar
Drives: 2013 "Hot Lava"
Originally Posted by Code Monkey View Post
I like this one.
None of them seem to do a proper calculation for any amount of stretch, where that original "frs project" page seemed to do a pretty good job. Most just ignore the effects of a wider rim (all things being equal, final diameter should decrease as you increase rim width) but this one might be considered worse since it seems to want to add surface area to the tire.
2013 Hot Lava FRS :: OFT Stage 2+ :: JDL UEL Catless :: JDL Over-Frontpipe :: GReddy Evolution RS Catback :: Enkei "Tarmac Black" RPF1 :: Tein Flex-Z Coilovers :: 245/35r18 Conti DW :: RS*R R-LCA :: Racer-X Fab R-Toe Arms :: Mishimoto Intake Tube :: Mishimoto Oil Catch Can :: JDL FSTB :: Raceseng "Slammer" + RLO :: Diode Dynamics HID + Tail-as-Turn + DRL :: 5:AD Spoiler ::
BurnetRhoades is offline   Reply With Quote
Auto Fitment Calculator itdansharpe Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 145 06-27-2018 03:59 PM
10 months old - battery dead this am. Auto off headlights? Large Issues | Warranty | Recalls / TSB 10 05-28-2016 10:12 PM
'13 BRZ Auto - Jerky when turning from a dead stop scottswan Engine, Exhaust, Transmission 7 10-03-2014 08:18 AM
Easy Wheel Fitment Calculator SLICVIC Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 05-13-2013 12:26 AM
Auto Fitment Calculator itdansharpe Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 12-28-2012 01:09 PM
