Drives: 2017 SUBARU BRZ
Question about wheels on the new BRZ.
Hey guys I just got a 2017 BRZ and I transferred the wheels I had on my 2015 COROLLA. I came to find out that the Corolla lug nuts did not fit on the BRZ. I am quite lost because Toyota uses the same 12x1.5. I ended up using the OEM lug nuts from the BRZ and torqued them on the aftermarket wheels.
Is it fine to use the OEM lug nuts on aftermarket wheels?
I was using those EBay tuner lugs with a conical seat. |
As long as the nuts and the wheels both have the same taper all is fine. You can't mix cone nuts with flat wheels or vice versa.
Drives: 2017 BRZ
The 86 uses M12x1.25
@ cjd, so that means the 2017 BRZ uses the M12x1.25 and NOT the 12x1.5
Drives: 2015 BRZ
Drives: 2018 BRZ tS (CBS), AE86 GT-S, MA70
12mmx1.5 is standard Toyota, Honda, and Mazda. 12mmx1.25 is Subaru and Nissan.
Since the 86 twins are manufactured by Subaru, well, you see where this is going. |
Huge E85 fan!
Drives: 2016 Scion FRS
Get a bigger breaker bar. It'll fit!
J/k don't flame me :-D |
I am a dumb ass. I overlooked the wheel info. offered on this site:
https://www.wheel-size.com/size/subaru/brz/2017/ Thank you all for the help. |
| Question about wheels. | lupindub | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 10-05-2015 04:39 AM |
| If I want many wheels? + Serious question | Mikeez | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 24 | 01-26-2015 11:18 PM |
| Question regarding my wheels? | koyv90 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 04-19-2014 01:27 PM |
| Question: Does Light Wheels = Weak Wheels | Gary in NJ | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 06-29-2013 10:08 PM |
| Wheels Question | Tsinoy | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 01-19-2012 01:45 AM |
