Old 12-27-2017, 05:49 PM   #1
TheWhiteWizard13
TheWhiteWizard13's Avatar
Drives: 2013 Subaru BRZ with Invidia N1
Exclamation finding the right adapters for a 17x 8 et 35 5x110 wheel
So im kind of new the world of wheels.. anyway im just going to jump right into it. i just got a set of my dads old saab wheels for xmas... the only thing is that they have 5x110 bot pattern. the dimensions are 17x8 et 35. I already know that im going to have to use 5x100 to 5x110 adapters, butttt the real question is about off set and fitment. Im looking at adapters that have a 25, 20 or 15 mm thickness so the offset might change from 35 to either 10, 15, 20. if anybody can help me with what the best adapter size is, that would be great.
TheWhiteWizard13 is offline   Reply With Quote
Old 12-27-2017, 06:12 PM   #2
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I would suggest that you get different wheels. But, since you asked....
The thinnest adaptor is going to be the easiest to make the wheel "fit".
You will need camber bolts, two sets, to adjust camber. This is just for the front. For the rear you will need LCA to adjust camber.
This is a 16x8 +25 with one set of camber bolts maxed out and lowered 1" on 225/50 tires. Your wheels, with a 225 tire and the thinnest adaptor will stick out an additional 5mm.
via Imgflip Meme Generator
I LIKE TIRES!
Old 12-27-2017, 07:20 PM   #3
TheWhiteWizard13
this makes me sad, but i do appreciate the insight. what do camber bolts do exactly? im still such a noob it makes my head hurt lol
Old 12-27-2017, 07:33 PM   #4
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Hello! Welcome!
They add camber.
GOOD LUCK!
I LIKE TIRES!
Old 12-27-2017, 08:33 PM   #5
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
You have two options.
1. 15mm adapters and but loads of camber.
2. Get different wheels.
I'd go with the second option personally.
That or see of you can get them re-drilled to 5x100.
Old 12-27-2017, 09:19 PM   #6
jamal
jamal's Avatar
Drives: Legacy GT
Sell them to a guy with a saab and get some wheels that fit.
jamal is offline   Reply With Quote
Old 12-27-2017, 10:17 PM   #7
TheWhiteWizard13
This has one of he most helpful answers, thank you for your feedback, even if I drill them the bore isn’t the same sadly 😓
Sent from my iPhone using Tapatalk Pro
Old 12-27-2017, 10:17 PM   #8
TheWhiteWizard13
My SAAB homie would love this response lol
Old 12-28-2017, 07:14 AM   #9
Grady
Grady's Avatar
The title to this thread should read “Finding the right wheels for my 5x100 hubs”
This is such a SAAB story!
Wheel Adapters... Will I die? Haroush Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 01-17-2019 10:11 PM
FS: isc wheel adapters 15mm, and eBay 25mm wheel adapters jay92 Brakes, Suspension, Chassis 4 08-19-2016 06:17 AM
I need help finding the right wheel for DD in the dirt. Hot Wheels Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 06-14-2016 11:41 PM
FS: Sparco steering wheel setup/ b2autodesigns wheel adapters sebastiansim NY / NJ / CT / PA 1 11-12-2015 07:57 AM
Has anyone ran wheel adapters? DarkCard Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 01-24-2013 09:07 PM
