Drives: 13 Scion FR-S
New to Cars
So I am starting to get into cars (I’m a noob!) and I own a ‘13 FR-S.
A few problems I am having with it: -Squealing noise when I start it up in the morning (30-45 degrees) not sure what it is?? -Check engine light, says it’s the o2 sensor, the o2 sensor has been replaced twice and it’s burned them up. I do not have a header but I do have a Borla axle-back exhaust on it ( pretty sure, haven’t jacked it up to see what exactly is going on under it ) . I got the car modified like this and not sure if it was tuned... or if it even needs a tune. I’ve been to multiple mechanics |
#2 | |
Axle back will not cause an O2 sensor issue. Positive there isn't a header?
#3 | |
It’s automatic And there is no header, I’m positive Sent from my iPhone using Tapatalk |
Hmmmm I am baffled then.
#5 | |
![]() On your next cold start, I suggest you open the hood, lean over the engine, have someone else start the car and see (hear) if you can isolate where the squeal is coming from. Since your car has an AT, my guess would be a lose serpentine belt or a bearing in the idler pulley or A/C compressor or the alternator. The axle back muffler shouldn't require the engine to be "tuned" nor should it cause a O2 code to be thrown. humfrz |
#6 | |
Ok I’ll do that thanks! I Just need to figure out this o2 sensor issue. Sent from my iPhone using Tapatalk |
[insert cool phrase here]
Drives: BRZ Premium
Sounds to me like you got someone else's shity tune. Contact previous owner ask them what kind of shity tune they put in there. Once you know bring everything thing back to stock factory settings.
The start up wine could be a lose belt. I guess since there is no vid or something.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
Drives: 13 mt fr-s
You could try an o2 sensor defouler, they are a super cheap option they may help ya'
#10 |
#11 |
Drives: 13 mt fr-s
Could be caking up your sensors by running too rich.
Or burning them out by running too lean. Can be caused by an aftermarket exhaust your car doesn't like. Try and find out if it was retuned... |
#12 |
Update: So the car was never tuned. So now what?
#13 |
Drives: 2015 Scion FRS
Are you replacing them with aftermarket 02 sensors or OEM ones? Also, no other codes? And how many miles on the car?
#14 |
Squeal could be a bad serpentine belt.
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
| Kit cars | pushrod | Other Vehicles & General Automotive Discussions | 56 | 09-09-2022 02:11 PM |
| CARS AND BAGELS/CARS AND CAKES car meet (SAN DIEGO) | edwinisdumb15 | Southern California | 2 | 07-03-2016 02:50 AM |
| CARS AND BAGELS/CARS AND CAKES car meet (SAN DIEGO) | edwinisdumb15 | Southern California | 0 | 06-26-2016 11:57 AM |
| Why do people lean on their cars when posing with their cars? | tzhu07 | Other Vehicles & General Automotive Discussions | 26 | 03-15-2014 08:51 AM |
| Kickstarter: MODARRI CARS (Cars for kids) | dem00n | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 02-04-2014 12:19 PM |
