Old 12-13-2017, 06:04 AM   #1
leevanf
leevanf's Avatar
Drives: 2014 BRZ Limited A/T
Oft stage 1 idle pattern?
Just flashed my stock stg1 oft tune days ago and driven just about 30km
I notice that every 10 seconds, a subtle switching sound clicks from the engine and my cars idle goes from 750 to 1000, then back down 750 - its not fast blips. Its as if it were taking deep breaths every 10 seconds. It happens both when stopped or even when in drive but of course if you step on the break the rplndoesnt rise up but you can still here something switching on to make it want to “breathe” to 1000. Is this normal? The constant switching on sound is kinda strange.
leevanf is offline   Reply With Quote
Old 12-13-2017, 06:44 AM   #2
elBarto
elBarto's Avatar
Drives: Toyota GT86
Airco kicking in. While idling open your hood and you will see the pulley being activated.
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
Old 12-13-2017, 06:46 AM   #3
leevanf
leevanf's Avatar
What does that mean in reference to the oft adjustments? I noticed it wasnt like this before the tune. Id get a mild idle bump maybe once every 15 minutes, but now its literally every 10 seconds sharp. Maybe the ecu still learning after tune ?
Old 12-13-2017, 08:35 AM   #4
Vin
Vin's Avatar
Drives: 2012 GT86 EU-spec
Yes ecu learning after clean flash, same goes for stock tune after it looses power and ecu is reset, the idle starts hunting a bit, especially when the car is not fully warm. Some cars do it more than others, sometimes it also seem to depend on the climate.
Vin is offline   Reply With Quote
Old 12-13-2017, 08:56 AM   #5
leevanf
leevanf's Avatar
Thanks! So i should not expect the full effects of stage 1 yet now right?
Old 12-13-2017, 09:23 AM   #6
elBarto
elBarto's Avatar
Drives: Toyota GT86
I think you have 90% of the tune or so after a flash. You're not going to feel an increase in power after the learning, only improved driveability.
Full Blown's New Build for the 2015 Season Stage 3 (2.19L motor) + Stage 3 Turbo kit FullBlown Forced Induction 47 06-20-2018 02:38 AM
FRS single stage vs dual stage driver's airbag mhiscott Issues | Warranty | Recalls / TSB 2 09-23-2017 03:43 PM
OFT Stage 2 UEL Help. Rough Idle Stalling shellslinger Software Tuning 11 03-05-2017 09:33 AM
Exedy Stage 1 Failure: Advice + Stage 2 Questions Pneub Engine, Exhaust, Transmission 4 07-18-2016 09:24 PM
FBM Stage 1 Cams w/ Stage 2 Head Results 743HP! FullBlown Forced Induction 119 03-24-2015 10:16 PM
