Northwest AK, ID, OR, WA
Old 12-11-2017, 11:39 AM   #1
SnipeD
SnipeD's Avatar
Drives: 15' FR-S MT
Had a blowout on way to work, tire?
Hey guys, had a nail ruin a tire on the way in this morning. I have 3 at 70-80%, any one have the factory tires wasting space? Come on I know everybody hates these tires. 😩 Portland area, hit me up.
SnipeD is offline   Reply With Quote
Old 12-11-2017, 03:47 PM   #2
HSUBLU
Drives: 2017 BRZ WR Blue
I've got all 4 at less than 3k miles. Just pulled them off the car like ten days ago.
HSUBLU is offline   Reply With Quote
Old 12-11-2017, 09:09 PM   #3
SnipeD
SnipeD's Avatar
Drives: 15' FR-S MT
HSUBLU to the rescue. Will be fixed up tomorrow.
Old 12-12-2017, 05:32 AM   #4
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Don't run different tires on the rear axle. In fact, if I had 1 tire blow out down even 20%, I'd get 2 new tires on the front or rear.
If you mix tires with different amounts of wear by getting used tires, measure the tire's diameter. Accurately. If they are not within about 1/16" of each other, don't use it. You will do damage with mismatched tires. Remember- the least expensive way in is often the most expensive way out.
just get 2 new tires.
Old 02-21-2018, 02:17 PM   #5
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
On a rear axle with a Torsen diff, will you expand on this subject? What damage and why?
PRO86 | STL | LuckyDog
Old 02-21-2018, 02:57 PM   #6
That is a little specific. Sure don't run different tires on the back but a 16th of an inch isn't going to hurt anything. I doubt even a 1/2 inch in diameter would hurt anything. I doubt there is a car out there where all the tires are within a 16th of an inch of each other. Hell a 2 pound pressure difference between your two rear tires probably gives you a difference.
Hankook RS3 blowout! TylerLieberman Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 01-24-2017 06:47 PM
WORK Emotion Wheels ** Winter Promotion || Free WORK Lugs or WORK Caps ** RavSpec Wheels and Tires 18 12-10-2013 05:19 PM
Tire blowout on truck in front of FR-S... Ouch! Leonardo Scion FR-S / Toyota 86 GT86 General Forum 36 08-31-2012 08:35 PM
