Drives: 2017 Halo 86
Can't decide on frontpipe. Suggestion?
Ignoring brand name, my setup is: uel catless header, stock over/front, resonated catback (muffler).
I just put the UEL header on and its currently pretty loud. I would like to tone it down a bit. So, I don't know just how much sound dampening I need to satisfy my specific needs (this is all new to me), but one thing is for sure I don't want too much rasp in higher rpms, and I don't want it to sound too muffled either. The options I'm looking at currently are: Dual catted & resonated: $849 http://www.ft86speedfactory.com/jdl-...-s-brz-86.html Single catted: $649 http://www.ft86speedfactory.com/jdl-...-s-brz-86.html Single highflow catted: $599 http://www.ft86speedfactory.com/moti...pipe-1301.html I've seen a couple youtube videos showing off these frontpipes, but there aren't very many to begin with, let alone used on setups specifically closer to mine. I'm also having a hard time justifying $200 more just for an additional resonated cat.. So, I feel like the highflow would be too loud, and the dual catted would be too damp, and the single catted would be juuuust right. Thoughts? Last edited by Lakitu; 12-08-2017 at 02:39 PM. |
If you want it quieter than the stock front pipe, only the dual catted will work. Even then, it might be louder than the stock front pipe. Otherwise the other two options will be louder than stock. Get a new catback.
| The Following User Says Thank You to swarb For This Useful Post: | Lakitu (12-08-2017) |
Ohne Titel
Drives: 2017 BRZ PP ISM
You might add the Fujitsubo dual resonated front pipe to your list:
https://frsport.com/double-resonated...p_1213521.html |
Drives: 2005 Toyota Camry
Sorry, if your current setup with a stock front pipe is too loud, it's because your exhaust is too loud.
You should consider changing that first. -alex |
You might want to check out CSG's Laguna Seca catback.
Aftermarket front pipes seem to have high-flow cats, I would bet that two of these would still be louder than the stock cat.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
Drives: frs
Mod for the sake of mod?
6/22/12-2/6/24
BTW, both single catted front pipes you linked are "high" flow 200 cells.
And I'd get the cat+resonator personally
You're not going to find a front pipe quieter than stock. If anything consider changing your catback to something quieter.
AVO Stage 2 Turbo Build Thread
https://wheelwell.com/tyler-nguyen-1...014-scion-fr-s |
| The Following User Says Thank You to tyler_win_photo For This Useful Post: | BirdTRD (12-10-2017) |
#10 |
Drives: 13 mt fr-s
Go back to stock cat back.
Get a duel resonated cat delete FP like HKS or Fujitsubo. Also Invidia's resonated FP is nice. But ya. Stock cat back would be the most tame. Biggest suitcase muffler. |
| HID Suggestion | kevinchavarria | Cosmetic Modification (Interior/Exterior/Lighting) | 17 | 10-17-2015 12:38 AM |
| suggestion | Calidrifter | Site Announcements / Questions / Issues | 0 | 03-24-2013 08:12 PM |
| A suggestion. | dem00n | Site Announcements / Questions / Issues | 4 | 03-16-2013 11:26 AM |
| Just a suggestion... | PuGZoR | Off-Topic Lounge [WARNING: NO POLITICS] | 33 | 12-08-2011 03:57 PM |
| Suggestion. | Negative | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 07-08-2011 01:59 PM |
