Drives: 13 FRS – Whiteout
Which header to pair w/$3,500 Amuse R1 CB?
So the previous owner of my FRS went ham w/the blue titanium Amuse R1 catback. I also have a Nameless Front Pipe/Over Pipe combo. Car sounds phenomenal as-is but I’d still like to remove any remaining torque dip with new headers.
My concern is the few YT videos I’ve seen with Amuse CB’s and a header is they sound horribly raspy - almost like an exhaust leak. The owners usually remark “yeah, it started sounding that way once I put the header on. That’s how a titanium exhaust ultimately sounds.” I find that hard to believe. I think they simply selected the wrong header. I don’t want to screw up the solid setup I already have. Any insight on whether I should hold off on the header and/or what I should pair it with? I also currently don't have much cabin drone at all - not looking to turn this into an alarm clock for the neighbors. Last edited by Clipping_Path; 12-06-2017 at 09:39 AM. |
Drives: 2013 Firestorm FR-S
Titanium exhausts definitely have a particular sound to them, and it can get loud when you open things up. See every S2000 with a J's Racing exhaust. Granted a big part of that is the F20/F22 engines, but S2000s are almost always one of the loudest cars at track days (especially those with titanium exhausts).
I'd suggest you spend money on something high quality, and keep the catalytic converter on. Is your Nameless setup resonated? That would help too. You may even want to look at the JDL Ultra Quiet front pipe setup.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Mr.Fujitsubo
Drives: 2018 STI
The only header I'd pair with this setup would be the Fujitsubo Catted Super Ex header. It's expensive though ^__~
2018 Subaru WRX STI ~ The Weekend Car ~
2015 Toyota 86 ~ The Sold Car ~ Build Journal OFT Stage 1 Tune Review ![]() |
Panda Trueno
Drives: No twin now.
Unfortunately it is incredibly hard for these cars to sound good. Performance wise, look at an ACE setup, but yes.... be prepared for it to sound raspy. Removing cats drastically changes the cars sound.
#6 | |
Mr.Fujitsubo
Drives: 2018 STI
Another option would be to sell your OP/FP and get one of the following setups. Apexi Header, Over-Pipe & Catted/Reonated Front Pipe This is a great quiet setup. Lots of information on it on this forum. https://frsport.com/Stainless-Steel-..._p_935110.html Or Fujitsubo Dual Resonated Catless Front Pipe (Proven to keep sound levels the same and not have any drone, rasp) You could than try some sort of catted header from JDL or FT86 to see how that will be. https://frsport.com/double-resonated...p_1213521.html
#7 | |
Proud of BOXER
Drives: Subaru Boxer
I would implore you to keep the stock header and the setup that you currently have.
| The Following 4 Users Say Thank You to Clipdat For This Useful Post: |
Drives: 2017 BRZ
Two things add noise with headers: removal of the cat, and thinner steel.
You can get catted headers, but they're not going to deliver quite so well on the gains. JDL does both EL and UEL, otherwise I think it's mostly UEL. But a catted header will probably leave torque dip. The best performing headers you can get any more are the Ace, if max gains are your goal. There are a few other good EL headers. If your Nameless overpipe/frontpipe combo is not catted and resonated, switch to one that is. That will help a LOT. And a cat in the frontpipe is where you want it for performance, not the header. The thin-ness of the material is a lot of why Ti exhausts are louder. So to a big degree, the only way to quiet it down is to change that. Adding resonators can help only so much. There's a point at which selling the fancy exhaust may be the better road to your goals.
Drives: Frs
I'm just wondering who buys a $3500 catback. Maybe consider adding a resonater to your FP.
JDL UEL Turbo GT2860RS, AP Racing BBK, Verus Splitter/diffuser/canards, Sard rep carbon wing, TFF bash bar, HKS hi power, Tein Flex A, Hotchkiss FSB, Radium MCB, Konig Hypergram 17x8, FS Indy 500, 6k HID, Whiteline trans bushing insert, Verus AOS, grimmspeed strut brace, Racerx oil cooler w/ setrab 619, ES steering rack bushings, Whiteline subframe bushings, Toms tails, STi mirror caps, IRP shifter, TRD Steering wheel
#10 | |
I agree with @Clipdat (this time) ...... I'd just leave it alone ....... ![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Sapphireho (12-06-2017) |
#11 |
Drives: 15 BRZ LTD, 05 FXT
What do you really want, just to lose some of the torque dip? Have you had your car tuned? That may do enough of what you're looking for. Adding a header will make it significantly louder, and may make you hate your catback.
If you're looking to make more power and keep it at similar sound levels, I think you should maybe look into a different catback. If you want the same sort of style, I have an MXP SP I like but have been looking into selling.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
#12 |
Drives: 2017 Series Yellow BRZ
Sell the Amuse exhaust, buy header and cat back that sounds the way you like, and have money left over for a tune.
| The Following 2 Users Say Thank You to Azzudien For This Useful Post: | JDM4E (12-06-2017), Slammillionaire (12-06-2017) |
#13 |
Drives: 2013 Hot Lava FRS
#14 |
Drives: frs
But why $3.5k cb?
| FT86 GT86 FRS BRZ OE STYLE DOOR PAIR (FOR TRACK USE ONLY) 10KG/PAIR | Aerostop | Groupbuys | 5 | 07-01-2017 03:41 AM |
| Best Header option to pair with OFT? | timmydatooth | Engine, Exhaust, Transmission | 21 | 04-05-2017 02:54 PM |
| SOLD C3M spacers (20MM pair and 25MM pair) | dar3d3vil | Wheels and Tires | 1 | 09-27-2016 11:25 AM |
| AMUSE header-back exhaust + ECUTek | aznatama | Engine, Exhaust, Bolt-Ons | 6 | 10-25-2015 10:26 PM |
