Old 11-29-2017, 09:23 AM   #1
Clash0901
2 ugga dugga's
Clash0901's Avatar
Drives: Nike
BMW ZF Getrag transmission into a BRZ mated to 2jz, ANYONE?
hello!
I was told by some supra guys that the BMW ZF 5/6 speed transmission is capable of holding 800ft lbs of torque. This transmission costs around $200-400 at any local junkyard by me so it's hard to ignore.
My question is, has anybody used this with the BRZ?
Also, I read somewhere that the stock BRZ trans is 34.5" from bell housing to center of the shifter, does anyone know if this is accurate?
The ZF trans is tiny and it's 30.75" from bellhousing to shifter center. This means some heavy modification of the shifter assembly will need to be done to "fit in the hole". Supra guys have no issues with fitting the ZF trans in the hole so it makes me wonder, does anybody know what distance the v160 trans is bell housing to center of shifter? This information will help me determine a lot of things going forward.
I am trying to avoid using the CD009 transmission mainly because I really want a 5 speed Getrag in this car. BUT, if this proves to be too complicated to complete in the BRZ then i'll likely switch to the CD009.
If I end up being the first one to do this i'll definitely make a thorough post of how it's done. However, it would be nice if I wasn't the first one though :P
Clash0901 is offline   Reply With Quote
Old 11-30-2017, 12:48 PM   #2
Clash0901
2 ugga dugga's
Clash0901's Avatar
Drives: Nike
FYI I bought this ZF 5 speed transmission today. 90% sure i'm going to be using it, i'll make sure to document everything required to do so for the BRZ. There's a small chance I will switch to the CD009 transmission but really don't want a 6 speed for this car.
Old 12-10-2017, 05:18 PM   #3
ort895
ort895's Avatar
Any update?
Yeah its an auto, deal with it.
ort895 is offline   Reply With Quote
Old 12-10-2017, 08:59 PM   #4
rob 2fast4u
rob 2fast4u's Avatar
Drives: 2JZ BRZ
how come no 6spd? I've always wanted a 6spd lol all my previous cars only were 5
rob 2fast4u is offline   Reply With Quote
Old 12-20-2017, 08:11 AM   #5
Clash0901
2 ugga dugga's
Clash0901's Avatar
Drives: Nike
6 speed is not good for 1/4 mile events and I don't care about fuel economy in this car. So the 5 speed makes perfect sense. If I change the rear end up, I should be able to trap this car at the top of 5th without losing any rpm's.
There are no updates yet, still trying to use the BMW ZF trans tho. I will be making a build thread shortly but really disassembly of the BRZ hasn't even started. Working on installing a lift first and ordering all the parts. I think the real work will begin sometime in January which is when my build thread will start as well.
Old 12-20-2017, 08:14 PM   #6
wulfgang
Drives: GBS BRZ
Originally Posted by Clash0901 View Post
I was told by some supra guys that the BMW ZF 5/6 speed transmission is a Getrag and capable of holding 800ft lbs of torque.
I'm confused, how can a ZF be a Getrag? ZF is a company that makes transmissions. Getrag is a different company that also makes transmissions.
wulfgang is offline   Reply With Quote
Old 12-21-2017, 07:42 AM   #7
Clash0901
2 ugga dugga's
Clash0901's Avatar
Drives: Nike
Yea you're right that's my mistake. It's a ZF trans not a Getrag.
Old 03-16-2019, 03:42 PM   #8
Joveen
Joveen's Avatar
Drives: Bone stock
Super bump! Can it be mated to the stock block?
Sent from my SM-N960U using Tapatalk
Joveen is offline   Reply With Quote
Old 03-20-2019, 03:26 PM   #9
Clash0901
2 ugga dugga's
Clash0901's Avatar
Drives: Nike
They make an adapter for sure to do this. Looks up "collins ZF to 2jz adapter"
Want to 2JZ swap your 86? Click here first!!
Old 03-20-2019, 03:39 PM   #10
Joveen
Joveen's Avatar
Drives: Bone stock
I meant the the stock fa20.
Old 03-22-2019, 01:48 AM   #11
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I feel like transmission swaps for the FA20 are non-existent. It would be cool to see something offered.
Old 03-22-2019, 02:56 PM   #12
wparsons
wparsons's Avatar
There's a CD009 swap kit...
flickr
Old 03-22-2019, 05:24 PM   #13
Irace86.2.0
Show me!
Old 03-22-2019, 06:20 PM   #14
Joveen
Joveen's Avatar
Drives: Bone stock
Show me!
Lmbo. How did you not know this hahaha. I'm only intrested in the ZF transmission because I'm using an IRP short shifter which would bolt up easily to that transmission. And they are cheap to find https://www.mazworx.com/mazworx-favq...t-frs/brz.aspx
JDL UQFP mated to Invidia Q300 help Zeuseidon Engine, Exhaust, Transmission 12 03-24-2017 07:58 PM
Does anyone have Perrin endlinks mated to an aftermarket front sway bar? loading_please_wait Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 07-22-2015 10:24 AM
Transmission? Pplater AUSTRALIA 1 06-05-2012 07:17 AM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
