Drives: 2017 BRZ Limited 6MT WRB
Opinion on $109 ebay special lip?
I've always liked how the STI lip looked but didn't want to fork out $400 for one. If only they had been available when I ordered the car and it had been included in the loan...
Anyway, I found this thing on ebay and its nice and cheap. Anyone have any experience with it? The pictures look decent but that doesn't really mean much. I'm tempted but I don't want to end up with something that doesn't fit worth a damn. |
Drives: 2013 Subaru BRZ Premium
You get what you pay for with this sort of thing.
It's poly so even if the fitment is poor it will be flexible enough that you'll be able to get it on the car easily enough but don't expect it to be functional at all or have much longevity to it. |
Powered by Crickets
Drives: 14' SWP MT Limited BRZ
I have the 2013-16 rep STi lip, and I compared it to my coworker's legit STi lip. The quality, finish, and fit are obviously non-comparable. The legit lip looks way better and the fit is superb. However, I'd still choose the replica. Because if I had to replace the lip, I'd much rather pay $100 than $400.
Build Thread / OFT Stage 2, Tomei UEL, Perrin Resonated, ST Coils, 2 Sets of Wheels, Rally Armor, TOMS Tails.
Drives: 15 BRZ LTD, 05 FXT
I view lips as consumable.
You can drive as carefully as you want, but if it's your DD it's going to touch stuff, if you go on long road trips there will be stuff in the highway. I've used the Bayson R lips from ebay and my opinion is that they've done a good job protecting my bumper. I'm down about 1.5 inches, and there are some entrances that are so steep, or such a drastic change from the road way that they just touch, and I'm glad it's scratching that $60 piece of plastic and not my bumper. I sanded it down with 500 grit to even out the finish, and I hit it with Wurth Cockpit when I'm doing underhood detailing.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
Drives: 2013 Subaru BRZ Limited (Black)
I agree with above. I have had a Bayson R lip ($60) for 2 years now, and i'm SO glad I have it. The lip scrapes and takes a beating that the bumper would otherwise (it's great insurance). And you'd be amazed at how often the lip will scrape on something if you are even an inch lower. The first time you scratch an expensive lip you will realize that it's not worth it to pay more than $100.
In my opinion, the Bayson R fits perfect. It's a great match for a $25k sports car. |
Time Traveller
Get the replica.
It's a DD not a show car so no one is going to have their eyes that low to the ground inspecting it. Besides the first time you scrape the authentic lip, it's going to look like shit anyhow close up. Body kit items and wheels take a beating. Do yourself a solid and save put the $300 you save on regular maintenance for your car. |
Ohne Titel
Drives: 2017 BRZ PP ISM
I bought a rep 2017 lip and it didn't fit worth a damn. Had to dremel quite a bit on one side to match the bumper contour. Wish I would've just bought the STI lip.
#8 | |
Powered by Crickets
Time Traveller
#10 | |
Time Traveller
#11 |
Country Boy 4 Life
I bought the absolute cheapest PU lip off Ebay. I think it was $79.00 shipped. I also bought 2 side skirts for $100 shipped. I bought everything to paint the parts too.
Sand paper 200, 400, 600, 1000, 1500, 2000 grits prep solvent sticky rag adhesion promoter primer Scion D6S paint clear coat I put the lip in the sun to heat it up and let it "un-warp". It looked good... I ground on it for a few hours. Then sanded it with all the grits. Then I painted and installed the cheap lip. It was crooked on one side. I took it off and carefully reinstalled it. This only helped a little. (you can sort-of see in the second pic the driverside lip edge turns up slightly...) A week later I was pulling into a spot at the lake. I hit a bump and ripped the lip halfway off. I was already over it at this point; so I took it off and threw it away. Long story short: It did not fit without lots of work. It was warped. And, unless you are stock height, it is pretty darn low. I am only lowered 1". The side skirts on the other hand worked out perfect. I love them! I ended up making aluminum mudflaps that protect the end of the side skirts.
I LIKE TIRES! |
#12 |
Thanks for all the replies guys. I'll probably end up getting one but not until next spring when its a little warmer out. I'm at stock ride height so I'm not too worried about bashing it on anything.
#13 | |
#14 |
Drives: 2015 Raven FRS
I have a Bayson R lip, well worth the money I think. I also made a plywood splitter with DIY frame mounts. Works great on the track, protects the front of the car, and being plywood easy to replace if it gets broken.
| Opinion on BBS Rim | DGM-BRZ | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-09-2016 07:28 PM |
| Opinion on these ??? | Sabretooth | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 01-03-2015 02:42 AM |
| Opinion on my next mod | ModalSoul37 | Northern California | 32 | 06-26-2014 05:39 PM |
| Special forum coupon - Edit: special has ended, Thanks! | bestwheelbase | Announcements, Contests, Giveaways | 6 | 10-25-2013 06:30 PM |
| Lightly Used Innovate Supercharger Setup Install Special! Locals Only Special! | Pure Automotive | Mid-Atlantic | 25 | 08-27-2013 01:00 PM |
