Drives: 2017 Toyota 86 M6
Do RacerX oilcooler fit Grimmspeed intake?
Everything is in the title! Want to know if the Racer X fits the grimmspeed intake since i want to get the Ft86MS oilcooler and they use the racer x sandwich plate.
If not can anyone comment what oilcooler fits the grimmspeed intake? Did some search and i think the perrin and mishimoto fits.. but i dont want to get the mishimoto and perrin is more expensive even tho i know its good quality |
Drives: 2017 BRZ
Far as I remember, none quite fit. Its up to the connectors at the plate, not the plate itself. Mishimoto uses banjo fittings which give a good bit of room... 45 degree AN fittings also seem to allow room... I remember all of them possibly needing a little bit of extra clearance.
#3 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
Perrin does NOT fit. It uses a standard mocal plate that doesn't fit with AN fitting or banjo fittings. The only possible option that I didn't try would be if it went straight over the oil cap but that would be a PITA to change your oil lol |
Drives: 2016 White Pearl BRZ Premium
I run the racerx sandwich plate and the grimmspeed intake. The AN fitting closest to the grimmspeed airbox eventually rubs a hole in it.
| The Following User Says Thank You to Joesurf79 For This Useful Post: | Qc86 (11-23-2017) |
Answer i was looking for thanks! I order the oil cooler and will be installing it when ill receive it. IMO shouldnt be a problem if theres is a small hole in the intake box.
Drives: GTS 86
Would JR radiator/Oil cooler fit with the Grimmspeed then?
#7 | |
The factory box it wore a hole in was a different story. The hole it rubs is on the clean side of the air stream
| kraftwerks oilcooler ? | dom_21 | Engine, Exhaust, Transmission | 1 | 08-05-2017 05:10 PM |
| wtb: Grimmspeed intake | AwdKngX | Want-To-Buy Requests | 2 | 11-08-2016 03:41 AM |
| FS: Grimmspeed Intake | GT86Dan | Engine, Exhaust, Bolt-Ons | 8 | 10-11-2016 02:28 AM |
| Skunk 2 Radiator/Oilcooler | oSoSlow | Engine, Exhaust, Transmission | 5 | 11-21-2015 12:21 AM |
| FS: Grimmspeed intake | SavingManuals | Canada Classifieds | 2 | 11-03-2015 06:39 PM |
